Sort of a long shot here... I am trying to repair a Yaskawa VFD. The unit powers up normally but when E stop condition is is cleared, the VFD should fire a magnetic contactor that will allow 3 phase power to flow into the diode packs to charge the DC buss. This is not happening and after 4 sec, the VFD will show an error code that the DC buss has failed to charge properly. More like not at all. I took it all apart and confirmed the MC coil is fine and that coil is turned on by a small relay. That relay is turned on via 24VDC from the control board, or rather one side of the relay coil is held at 24VDC and the other side should pull low to ground to fire the relay coil. That does not happen either.
So that moved me to the actual control board in which it appears a proprietary microcontroller fires a 3 leg SMD transistor that has a marking "L33". It is VERY small but I believe the uC sends signal to the transistor and one side of it is held at ground potential and when fired, should connect ground at that transistor.
I will need to test a bit more it appears either the transistor is bad, or it is not receiving signal to turn on which could either be a bad microcontroller or maybe dirty power. It is very common in this older drives to have bad capacitors that cause issues. I can see a "few" were replaced but appears they went cheap and did not replace all of them, which there are only 8 on the entire control board.
The micro controller says Yaskawa on it and I have not been able to pull any data on it. Figures they had proprietary markings made up for them. I am temped to just replace all the caps first but would really like to source the problem before swapping random parts.
There is a small power supply for the board and nothing else shows errors. The PSU provides what appears to be 5V and 24V, in which the 24V is at 23.8V and 5V was at 5.10V ,there was another voltage at around 18V I believe. I did not test them for AC but I can. There is that possibility that the PSU has issues that are causing this. Something like this industrial VFD, caps become the very first concern.
But, assuming the transistor is of issue, is there any way to determine what the L33 is?
