unsigned char ReadEeprom(unsigned int badd )
EEADR = (badd & 0x0ff);
CFGS = 0;
EEPGD = 0;
RD = 1;
return ( EEDATA ); // return with read byte
void WriteEeprom( unsigned int badd,unsigned char bdata )
EEDATA = bdata;
EEPGD = 0;
CFGS = 0;
WREN = 1;
GIE = 0; // if used remember re-enable, interrupts cannot be on
0x55;
0xAA;
WR = 1;
while(WR);
//GIE = 1; // if used remember re-enable
WREN = 0;
delay(10000);
while(location_enter==0) //loop until location_enter flag is set
lcd_goto(0); //set the lcd cursor to location 0
send_string("Choose User "); //display string
lcd_goto(20); //set the lcd cursor to location 20
send_string("User "); //display string
lcd_goto(25); //set the lcd cursor to location 25
send_char(0x30 + location); //display character (numerical digit which started from 0x30 or zero)
if(!But1) //if SW1 is pressed
while(!But1); //waiting for release
if (location<5) //if location is not reaching 5
location++; //increment by 1
else
location=1; //reset back to 1
else if(!But2) //if SW2 is pressed
while(!But2); //wait for release
if (location>1) //if location is not reaching 1
location--; //decrement by 1
else
location=5; //reset back to 5
else if(!But3) //if SW3/Confirm is pressed
while(!But3);
mem = 0x10 + location; //waiting for release
store_eeprom(mem,location); [B]//<<<<--------- this one,[/B]
AddNew(location); //function call for add new fingerprint into database at desired location
void view_user(void)
lcd_clr(); //clear lcd
mem = 0x10;
send_string("User 1 2 3 4 5 "); //display string
lcd_goto(24); //set the lcd cursor to location 20
unsigned char x;
mem = 0x10; [B]//<<<<----- memory location[/B]
for(x=1; x<6; x++) //loop 5 times for 5 days
{ send_char(0x20); //display " "
mem = mem ++;
TEMP=get_eeprom(mem); //retrieve marking[B] <<<---- will read the eeprom[/B]
send_char(TEMP); //display marking
delay(500000);
lcd_clr();
//store data into specified location in EEPROM
void store_eeprom(unsigned char location,unsigned char data)
EEPROM_WRITE(location,data); //write data
while(WR) //wait until it finish
continue;
//access EEPROM to retrieve data
unsigned char get_eeprom(unsigned char mem)
unsigned char value;
value= EEPROM_READ(mem); //read eeprom and assign the data to variable
return value; //return data
