I would like to know how to wire 3 x 3 sets of 4 LED's hooked up in parallel to a chaser. they would be powered by 8xaa batteries (12v). can I wire the 3 sets in parallel and the 4 LED's in each set in series with a chaser? so that every 4th LED lights up then the next... I would like to have 3 strings of this configuration hooked up to the battery for a total of 36 LED's. And is there enough power to have all the lights on at the same time, if so how would I wire this into the setup The LED's would be 3mm x 3.0v x 20mA. which resistor/s should I use. I am looking for the easiest/cheapest way to do this.
