I have an idea to start a small project related to cable TV transmission. Normally signal transmit from the tap to decoder through cable, is that right. My idea is to use wireless transmission insted of cable probably 100M distance.
I need transmitter and receiver at the both end. I saw a transmitter in RS catalogue at range of 2.4 G but input is DVD o/p i think in UHF range (in Mhz). I think such module can be used with small addups.
Cable Tv transmission is on following freqs.
Transmit from tap (forward) 77Mhz to 750 Mhz
(Return ) 5Mhz to 55mhz
At the decoder (Receiver ) 77 to 750 Mhz
(transmit) 5 to 55 Mhz
What kind of Tx/Rx need to be used to facilitate above freqs.
Cable TV has both way communication. Basically I need to replace Cable with wireless media.
Do you have any ideas related this or any website learn to improve this idea.
Your help much appreciated
