Faithhaven
i have a wine cooler that i would like to convert to a queen bee larvae incubator. most diy projects are done by people with minimal or no electronic knowledge. So I thought I would seek advice from the experts. the temperature the larvae require is 92 degrees and approximately 50% humidity. The present thermostat has a maximum temp of 62 degrees. Is there a way to modify the temperature range and if necessary add a heater. The external temps can be high as I live in the desert and we are all experiencing the present drought conditions here in California. The usual configuration is a 40 watt incandescent light bulb, for heat, a fan, for convection, a bowl of water, for humidity and a stable thermostat +- 1 degree. Any assistance in this project will be appreciated.
