wierd problem with 16f628
eeanma
I'm trying to use 16f628's porta as an output but for some reason it doesn't work. at least when i'm simulating with mplab's simulator. the problem is that i cannot change the state of porta's 0-3 pins. They are always 0. so only RA4 is working.
my code is:
LIST P=16F628
radix hex
#include "P16F628.INC" ; Include header file
__config _INTRC_OSC_NOCLKOUT & _LVP_OFF & _WDT_OFF & _PWRTE_ON & _BODEN_ON
ORG 0x000 ; Program starts at 0x000
BSF STATUS,RP0 ; bank 1
CLRF TRISA ;all output
BCF STATUS,RP0 ; back to bank 0
CLRF PORTA
LOOP:
BSF PORTA,4 ;RA4 goes up
BCF PORTA,4 ;RA4 goes down
BSF PORTA,3 ;nothing happens
BSF PORTA,2 ;nothing happens
BSF PORTA,1 ;nothing happens
BSF PORTA,0 ;nothing happens
GOTO LOOP
END
can you see any clear errors or have you had same kind of problem??
Or is the error in simulator??
a
PIC 16F628 has comparators on portA. They are ON by default, so if you want ,to use portA pins as normal I/O you must first turn the comparator off
Add the following lines to the top of your code
MOVLW 0x07
MOVWF CMCON
