It's real basic but still like other's suggestions.
Not sure about the best site to post on for help.
I'll post here anyway if it's suitable. My apologies if not.
Thanks very much.
I'm adding a remote trunk release to my car.
It's factory remote only locks and unlocks the car.
I can access a 12V signal, a momentary pulse, that goes to the door motors. There is actually 2 wires that go to the doors, both are normally at GND but either one get a 12v pulse to either lock or unlock.
The only idea I can come up using the factory remote is have the trunk solenoid fire when a 2nd 12v unlock door pulse is detected within a couple of secs of the 1st unlock pulse. ie 1 press unlocks the doors, 2nd press pops trunk. If 3-4 secs have passed 2nd unlock won't pop the trunk.
I could use a 555 cct but I'm wondering if there's a simpler way to do it.
I also need to make sure that no part of the 1st pulse fires the trunk. I thought perhaps the following might be a problem.
The rising edge of the 1st pulse energies a timed relay closing it's contact therefore allowing the next pulse thru it's contacts, but, since the 1st pulse is still present when the contacts close the trunk will fire on the 1st pulse.
Any ideas ?
Thanks veru much
Scott
Thanks very much.
Any ideas ?
Thanks veru much
Scott
