what's wrong with this chunk of code for pic16f876a
Mehmood Ahmed
this section of code has been written for getting data from tristate buffer IC using multiplexing technique but it's not working. compiler being used is HITECH C whereas I wrote same section of code using CCS C compiler and it works fine. In that version I used its library functions. I am putting here both the versions. Please suggest what wrong I am doing with HITECH C version of code. Thanks
HITECH C version
unsigned char getdata(unsigned char address)
 unsigned char x;
 switch(address)
 case 0x1:
 	RA0 = 0;
 	TRISA0 = 0;
 	TRISB = 0xff;
 	x = PORTB;
 	RA0 = 1;
 	TRISA0 = 1;
 break;
 case 0x2:
 	RA1 = 0;
 	TRISA1 = 0;
 	TRISB = 0xff;
 	x = PORTB;
 	RA1 = 1;
 	TRISA1 = 1;
 return x;
CCS C version
 unsigned char x;
 switch(address)
 case 0x1:
 set_tris_b(0xff);
 output_bit(PIN_A0,0);
 x = input_b();
 output_bit(PIN_A0,1);
 break;
 case 0x2:
 set_tris_b(0xff);
 output_bit(PIN_A1,0);
 x = input_b();
 output_bit(PIN_A1,1);
 break;
 return x;
Yesterday I found the Solution by studying datasheet...port a of PIC16F876A by default is configured as analog input. So I had to configure first four bits of ADCON1 register. I set ADCON1 = 0b00000110 which made port a pins as Digital I/O that's it...Thanks for help by all of you
