Django Fawkes
Hi, not sure if this is in the correct forum, so if mods move or delete, i'll understand, but here goes:
I plan to buy **broken link removed**
and use without plugging directly into mains, but plugged into an inverter which linked to a car battery. As it is pricey for me, I need to be sure what type of inverter I require for either a 12 or 24v battery (preferably 12v) and whether the speaker is suitable to use with this setup. The speaker itself has a power supply which converts mains supply to 48 volts.
here is the specs:
Wattage 100 watts maximum
Input 100V - 240V ~ 50/60 Hz
Output 48V DC @ 2.08 Amps
My thoughts is if I connect the AC 240v to 48v DC power supply to the inverter and the inverter to the battery, it should be ok.
On a further note, it is likely to be an american plug, so I will need an international adapter, making it:
car battery-->inverter-->international adapter-->AC 240v to 48v DC power supply-->speaker
Two questions then, first, what type of inverter do I need, say out of this list:
https://www.maplin.co.uk/search?criteria=inverter
And is it guaranteed safe and won't destroy the speaker?
here is the specs:
