what might be the problem??
rohaan
hey!
my 7 segment display is not working properly..
only its "e" side is glowing and all are off..
i change the decoder and also change the seven segment..but still its giving the same..
what might b the problem it have?
its common anode..?
is it only the loose connection or what???
Rohaan.
rohaan said:
hey!
its common anode..?
Rohaan.
I dont follow what you are saying,,,only its "e" side is glowing and all are off
Rohaan, we may be able to help you. I think you mean that ONLY the "E" (lower left rising) segment is lit. However, You will have to give a bit more information, like what decoder are you using , what info are you feeding the decoder and if at all possible a circuit diagram of what you have so far.
Cheers RH
Have you tested the display if it works OK ?
Connect 5 Volts dc via the correct value series resisitor to keep the segment current below 20 mA to the CA terminal(s) of the display.
Then touch the individual segment pins with a jumper to negative.
As you test you identify the pins and each segment should lit up.
Also some 7 segment displays may require a jumper to drive 2 CA terminals off the display.
And are you sure it is a CA and not a CC display ?
thanks for the comments..
i have got the problem which i was doing..it was the ic pin
thanks again :)
Rohaan.
