what is the function of an oscillator within an inverter circuit?
JAMES IRVINE
This may seem like a stupid question, I thought I knew the answer to this but I think there is more than one answer to it and the question is to "clearly explain the function of an oscillator within an inverter circuit"
My initial thought was that it provides commutation to switch on and off switches alternatively like thyristors for example.
However I know that it's possible to create a true sinewave using positive feedback although this is very difficult so I know there is a big gap in my knowledge so may'be someone can think of another reason for oscillations? I can't think of another one at the moment.
The electricity in your home is AC at 60Hz in North America or 50Hz elsewhere. It is a sine-wave.
An inverter uses the power from a huge battery to create 50Hz or 60Hz at the same voltage as the electricity in your home but the waveform can be a square-wave for a very cheap circuit and many electronic products won't work from it, or the waveform can be a modified sinewave that is a little more complicated but nearly all products work from it, or the waveform can be a pure sine-wave which is made with a complicated circuit.
The oscillator in the inverter creates the 50Hz or 60Hz.
If you use a sine-wave oscillator driving a linear power amplifier then the amplifier wastes a lot of power as heat. The battery current is double what a modern circuit would be.
A modern sine-wave inverter uses a high frequency voltage stepup circuit that has a tiny transformer and a rectifier to make high voltage DC. Then another high frequency high voltage circuit uses pulse-width-modulation to create a stepped sine-wave then a small high frequency filter smooths the steps into a pure sine-wave. The parts that operate at high frequency barely get warm because they switch on and off.
Also not that if you're going to build an inverter or design an electrical system that uses one like a UPS or alternative energy supply use as high as DC input voltage as you can. Ohm's law states that to transmit the more power you need to increase either the current or the voltage. Increasing the current leads to large losses in the cables which will need to be thick bulky and expensive. I'd strongly recommend using 48V as it's too low to electricute you (unless you have really damp skin so keep away from water) and the current that delivers the same power is one quarter of that at 12V.
Try Wikipedia, look up Inverter. Google and Wikipedia will reduce your need to ask questions here by a huge amount and give you more detailed information and reading refrences. Wikipedia in particular has a larger number of articles on electronic circuits of every kind.
I am assuming you're just asking for inverter(DC to AC) operation circuit not the entire inverter product.
In the inverter circuit the controlled switches(IGBT/mosfet) will be used. To control the switches you use micro-controller/DSP processors. These processors generates the required pulses with desired frequency.
Generally a specialized oscillator, called the clock, serves as a sort of pacemaker for the microprocessor. The clock frequency (or clock speed) is usually specified in megahertz (MHz), and is an important factor in determining the rate at which a processor can perform instructions.
Thks Jim- didn't notice OP date- Please delete
Ancient thread alert!
I found in some forum, if the thread is pretty old then there's a alert in red color already, so people can decide what to do with the thread. I wish to see such automated alert here too.
