goodpickles
everybody says that it is different, but nobody can tell me why, or how to convert between Volt Amps and watts.
VA's represents the combination of the two. if you look at it in terms of complex numbers and vectors, Real power is a vector on the real axis, Reactive power is a vector on the imaginary axis, and the sum of the two is what is represented by VA's.
An example I heard is that power companies try to use capacitors to alter the impedance of buildings they supply power to. this is to get the building to "look" as much like a resistive load as possible, thus reducing the reactive component of the power, and making the total power as close to the real power as possible; this is because in effect the cost of supplying the customer with electricity is proportional to the TOTAL power (VA's) while the customer really only pays for the REAL component of the power they get (Watts) so they want to make the total power as close to the real power as possible to save themselves money
goodpickles said:One other related question. A friend told me that one of his neighbors back when he lived in...had a battery charger that actually made the power meter run in reverse! The power company found out and gave the man a new charger. The reason that it did this was that the power factor was so far off.
I understand that something with a lower power factor that 1 show as if it was taking less energy as it really does, but would it actually make the meter run in reverse?
Following a fault, when the voltage on the line is trying to come back, there can be a case where if the line is not "strong" enough (higher impedence), then all motors coming back on line together present such a reactive load that it can make it impossible for the voltage to come back up, leaving the line at 50% or less of nominal for some time (or indefinately, until something trips) doing all kinds of damage. I guess this is especially a problem where there are a lot of air-conditioners and such, whose motor controllers don't have a low-voltage release
