mstechca said:An npn transistor is two diodes with their anodes connected to each other.
A pnp transistor is two diodes with their cathodes connected to each other.
Nigel Goodwin said:mstechca said:An npn transistor is two diodes with their anodes connected to each other.
Its amazing. Hundreds of sources say what I say, and people like you turn around and say it is misleading. Cmon INTERNET, Get the FACTS straight!!!Rather misleading!
I wonder if this is the reason why so many people ask these "why doesnt this work" questions.
I must have use the wrong word (is). But I was merely describing how an "ideal" transistor functions.- a transistor is NOT two diodes connected together
An ideal transistor cannot function the way two diodes would do back to back
then I must be partially right, because I know that I can use the base and emitter junctions and treat them as a proper diode. The collector isn't the same.it is the thin doping of the base that makes a transistor work!
mstechca said:Its amazing. Hundreds of sources say what I say, and people like you turn around and say it is misleading.
You made a lot of sense until this statement. Can you explain what you mean? How are you going to turn a transistor on when the base is shorted to the emitter? If you do what you suggested, you simply have a forward-biased base-collector junction. There is no transistor action here.DigiTan said:One quick & dirty way to test both kinds is to "saturate" the base pin by connecting it to the emitter (maybe through a button) so that the transistor operates on an on/off basis. To test NPN, connect the emitter+base to positive, , and the collector to negative; and if the trans works, you'll get a large amount of current going out of the collector. For PNP, connect emitter+base to negative, and collector to positive.
mstechca said:the reason why I was saying that transistors are two diodes back to back, because it "basically" answered his question.
I also agree that two diodes back-to-back wouldn't make one of today's transistors, because it wouldn't account for half the transistor's parameters.
Ron H said:You made a lot of sense until this statement. Can you explain what you mean? How are you going to turn a transistor on when the base is shorted to the emitter? If you do what you suggested, you simply have a forward-biased base-collector junction. There is no transistor action here.
Perhaps you have transposed collector and emitter?
