what does it all mean, transistors specs for specs!
the cracken
here is a transistor i have and i cant make heads or tails of this spec help plz thanks
SFT323
Ge PNP Lo-Pwr BJT
Various
V(BR)CBO (V)=24
I(C) Abs.(A) Collector Current=250m
Absolute Max. Power Diss. (W)=200m
I(CBO) Max. (A)=15u
h(FE) Min. Static Current Gain=85
@I(C) (A) (Test Condition)=100m
@V(CE) (V) (Test Condition)=1.0
f(T) Min. (Hz) Transition Freq=2.6M
Status=Discontinued
Package=TO-1
Military=N
SFT323
Germanium PNP
N/A
Category: Germanium Transistor, PNP Transistor, Transistor
MHz: <1 MHz
Amps: 0.5A
Volts: 32V
It's a Germanium transistor which means it's very old, obsolete and is no longer be made: status = discontinued.
What spec's are you having problems with?
It looks fairly standard to me.
i want to make a simple amp from one. so i guess what ever i need to do that :D
You mean a common emitter amplifier?
You really haven't provided enough information but you could help yourself first by using a transistor which is still made.
yes a common emitter amp will do.
thats all the information that i could find. What information am i missing?
You're missing lots of information.
Before you build an amplifier, you need to know the required gain, input/output impedance, bandwidth, power supply voltage etc.
