What does a comparator do ?
Hi all, I have a comparator LM339M, what is its main purpose ? It has 4 inputs and 4 outputs as well as a Vcc and ground connection. When do the outputs go high ? Can you explain the basics. I do'nt have a specific purpose intended for it, I just want to know when outputs 1-4 go high or low and when and why..... Thanks in advance.... Jim
jbelectric777 said:
I just want to know ... Jim
Check out this site for all you ever need to know: home.cogeco.ca/~rpaisley4/Comparators.html
LM339 sounds like an analog comparator... These have two inputs and one output...
One of the input is called the non-inverting input (+) while the other is an inverting input (-)
When the voltage at the + terminal exceeds that at the - terminal, the output is high.
When the voltage at the - terninal exceeds that ath the + terminal, the out put is low.
Ex:
+ = 2.5v
- = 6v
Output =Low...
if
+ =5
- =-6
Output=High...
There are also some digital comparators...
Where two digital words are compared and the output is either 1 or 0...
LM339 is a current sinking comparator, so the outputs are either tied to ground, for a logic 1, or high resistance, for a logic 0.
