What capacitors for 32 kHz crystal?
Ecir Hana
Please, does any one know whether 32 kHz crystal oscillator needs a pair of capacitors? If so, what values should each have?
Depends on the crystal spec. Many 32 kHz crystals made for low power oscillators are specified for 9 or 10 pF loads.
If it is a leaded IBP tubular package (like seen in computer motherboards) I would guess 10 pF load. Don't forget to take PCB and IC capacitance into account. For 10 pF net load, try 15-18 pF on each side to ground (3-5 pF across Xtal for IC and PCB strays).
Avoid ground plane below crystal pads, PCB runner, and IC input pins as these can add a couple pF to loading. If you are using a raw CMOS inverter you need a series resistor on output to xtal as too much drive can destroy crystal.
It also depends on what you connect it to. For instance, at least some of the AVR micro-controllers have a timer clock input intended to be used with just the 32kHz crystal and no capacitors.
