Weird code execution
kyru27
I've the following code:
	LIST	p=18F4620	;Tipo de PIC
	#include <p18F4620.inc>
;	CONFIG DEBUG = ON
	CONFIG OSC = INTIO67
;Define la posición del resultado
CONTADOR EQU 0x22
	ORG 0x0000			;Comando que indica al Ensamblador
						;la dirección de la memoria de programa
							;donde situar la siguiente instrucción
	MOVLW 0x06
	MOVWF ADCON1
MOVLW 0x10
MOVWF TRISA
MOVLW 0x00
MOVWF TRISC
MOVLW 0x3F
MOVWF PORTC
INICIO		CLRF CONTADOR
P1			BTFSC PORTA,4
			GOTO P1
P0			BTFSS PORTA,4
			GOTO P0
INCF CONTADOR,F
MOVLW 0xA
SUBWF CONTADOR,W
BTFSC STATUS,C
CLRF CONTADOR
MOVF CONTADOR,W
CALL CD7SEG
MOVWF PORTC
GOTO P1
CD7SEG
ADDWF PCL, F
            retlw    06h
            retlw    5bh
            retlw    4fh
            retlw    66h
            retlw    6dh
            retlw    7dh
            retlw    07h
            retlw    7fh
            retlw    67h
			retlw    3fh
END
That works in an awkward way, I mean, when CD7SEG is called the following values are returned according to the value of CONTADOR:
When CONTADOR=1 ->"1". OK
When CONTADOR=2 ->""2. OK
When CONTADOR=3 ->"2".
When CONTADOR=4 ->"3".
When CONTADOR=5 ->"3".
When CONTADOR=6 ->"4".
When CONTADOR=7 ->"4".
When CONTADOR=8 ->"5".
After this the program stops recognizing that the button which allows to jump to INCF CONTADOR,F is being pressed and the program cannot be executed properly anymore.
Any idea of what might be happening? It's pretty strange that the code works right for the first two numbers, and later it doesn't work.
Thanks.
This is because tables work a different way on the pic18's The table call requires a high and low address
MIKEK8LH is the man to ask he explains it here https://www.microchip.com/forums/m100230.aspx. Read this and you will be enlightened.
[Ian beat me too it.!:rolleyes:]
Look at this extract from the d/s when using the Computed Goto with a 18F PIC
