The following is all written in C18 and tested with the Oshonsoft simulator, which is an excellent bit of software.
I'm trying to write some basic LCD code that uses delays, so I can save the RW pin (yes, I've ordered the bits for the 2 wire interface!).
This function works fine for a normal LCD and I can get the word "Test" on the display:
LCD_RS is just defined to the right LATA pin, I'll do the same for LCD_DATA later.
So I tried to make an LCDNibble (like the 2 wire example has):
And I call it like this:
I have tried with and without the temporary variable, e.g. calling like LCDNibble((c>>4)&0x0f, 0). However this displays "P`pp".
I'm really tempted to simply have two seperate functions that do their own port setting but there must be something funny that the compiler does which breaks it. Or maybe I've been really stupid!
Can anybody spot my mistake?
void LCDChar(unsigned char c) {
LATB = (c >> 4) & 0x0f;
LCD_RS = 0;
LCDEnable();
LATB = (c & 0x0f);
LCD_RS = 0;
LCDEnable();
Delay5ms();
return;
void LCDNibble(unsigned char n, unsigned char rs) {
//LATB &= 0xf0; // Clear lower 4 bits of port
//LATB ^= n; // Move nibble to port (COMMENTED FOR TESTING)
LATB = n;
LCD_RS = rs; // Set RS line
LCDEnable(); // Pulse EN line
unsigned char tmp;
tmp = (c >> 4) & 0x0f;
LCDNibble(tmp, 0);
tmp = c & 0x0f;
LCDNibble(tmp, 0);
Delay5ms();
return;
