Hello Everyone,
long time no speak.... (sorry I really should get around to inputting to the community)...
I am working on a project to create automation systems for functions that are currently manual....
I have the main points down, TCP/IP and various normal relay controls with latching and non latching relays etc.. However, I'm really struggling with one point...
The system at the moment im stuggling with is an audio input selector to a Audio IR modulator and transmitter. The WIR TX 925 has two channel inputs, which it modulates for IR headsets to pick up.
We use a 2 pole, 6 way rotary switch to connect several different input source options to the 2 channel inputs...
My aim, is to automate this.
I'm really struggling to find a solution to this, I've looked at bus switches and all sorts, but finding a UK avaliable part is difficult (also that I understand, and can solder (Smd/SOIC is a no no)).
I would, if possible want to retain a manual override should the TCP commands not work, but that would be a simply switch input to the IC controller (Picaxe, nice and simple for this usage, I know its an Education type chip and not true hobbyist, but hey ho! I like them!!) which then controlls the output in the same way...
I suppose a bank of relays could work, but as latching relays are expensive, its not ideal for a tight budget again I could use normal relays but I dont want to drain unneeded power on a system that will be powered 24/7.
has anyone any experience with similiar projects?
Thanks in advance,
Owen.
PS. I've never used multiplexers before so wouldnt know if they are suitable for this analogue design
Thanks in advance,
Owen.
