i have written a program with the scope of lighting leds using interrupt on change on port 3 but unfortunatly though the micro goes into sleep it won't wake up... i have tried all the other I/O lines and everything is like in the tutorial
http://www.electro-tech-online.com/custompdfs/2009/09/PIC_Mid_A_7.pdf
still the program won't work.. at least surely in the Mplab sim....
one other thing i noticed is that the GPIO pin of pin GPIO3 is always set... why is this so? is it because gpio3 is always an input?
thanks a lot
;PIC12F629
;This program is made to read an input from Gp3. each time it gets set it will switch the next led on.
;The program goes in to sleep and wakes only when the switch is set..
;uses the internal oscillator
#include <p12f629.inc> ; call header file of pic12f629
CBLOCK 0x20
PORT_SHADOW
ENDC
LIST P=12F629 ;SET MICROCONTROLLER USED
ORG 0 ;reset vector
GOTO START_SETTINGS
;NO ISR USED, INTERRUPTS NEEDED ONLY TO WAKE UP FROM SLEEP
;Configuration Word
__CONFIG H'3FC4' ;SELECTS INTERNAL OSCILLATOR WITH NO CLOCKOUT, MCLR INTERNAL, BOD AND POR= ON, PORTECTION OFF
START_SETTINGS
BANKSEL CMCON
MOVLW B'00000111' ;SET DIGITAL INPUTS
MOVWF CMCON
BANKSEL TRISIO
MOVLW B'00000000' ;SETS ALL PORT BITS TO OUTPUT EXCEPT FOR BIT3 WHICH IS ALWAYS AN INPUT
MOVWF TRISIO
;NOTE THAT GP3 DOESN'T HAVE AN INTERNAL WEAK PULL UP
BANKSEL OPTION_REG
MOVLW B'00000100' ;SETS SOURCE OF TMR0 TO INTERNAL OSCILLATOR AND PRESCALAR TO TMR0,PRESCALAR SET TO 1:32
MOVWF OPTION_REG
;INTERRUPTS: SET THE INTERRUPT ENABLE FOR PORT CHANGE BUT DO NOT SET THE GLOBAL INTERRUPT..
;SO THAT THE MICRO WOULD WAKE UP FROM SLEEP BUT NOT GO THROUGH ISR
;AT SLEEP THE I/O WILL STILL WORK NORMALLY
BANKSEL INTCON
MOVLW B'00001000' ;PORT CHANGE INTERRUPT ENABLED
MOVWF INTCON
;SWITCH OFF TIMER1 AS IT WILL NOT BE USED
BANKSEL T1CON
BCF T1CON,0
BANKSEL IOC
BSF IOC,IOC3
;CALIBRATE THE OSCILLATOR
BANKSEL OSCCAL
CALL 3FFH
MOVWF OSCCAL
;PROGRAM STARTS HERE
;PORT_SHADOW RES 1
START CLRF PORT_SHADOW ;RESET SHADOW
BANKSEL GPIO
MOVF GPIO,W
BSF PORT_SHADOW,0 ;SET FRIST LED
MOVF PORT_SHADOW,W
MOVWF GPIO
; CLRWDT
SLEEP ; GOTO SLEEP
;IF WAKED UP IT MUST BE SINCE THERE IS A PORT CHANGE, I.E IN BIT 3
;THUS WAIT FOR IT TO GO LOW(SWITCH DEPRESSED)
;WHEN IT DOES, READ THE PORT AGAIN TO STOP THE CONDITION AND GO BACK TO SLEEP
BANKSEL GPIO
MOVF GPIO,W ;READ SO TO SWITCH OFF CHANGE" CONDITION
BCF INTCON,GPIF ;CLEAR FLAG
BCF PORT_SHADOW,0 ;CLEAR FIRST LED
BSF PORT_SHADOW,1 ;SET THE NEXT LED
MOVF PORT_SHADOW,W
MOVWF GPIO
;CHECK WHETHER SWITCH IS DEPRESSED
CHECK BTFSC GPIO,3
GOTO CHECK
;DEBOUNCE DELAY
NOP
NOP
NOP
NOP
SLEEP
BANKSEL GPIO
GOTO START ;START AGAIN
END ;PROGRAM STOPS HERE
thanks a lot
regards
thanks a lot
;PIC12F629
CBLOCK 0x20
PORT_SHADOW
ENDC
ORG 0 ;reset vector
GOTO START_SETTINGS
;Configuration Word
START_SETTINGS
BANKSEL CMCON
MOVWF CMCON
BANKSEL TRISIO
MOVWF TRISIO
BANKSEL OPTION_REG
MOVWF OPTION_REG
BANKSEL INTCON
MOVWF INTCON
BANKSEL T1CON
BCF T1CON,0
BANKSEL IOC
BSF IOC,IOC3
BANKSEL OSCCAL
CALL 3FFH
MOVWF OSCCAL
;PORT_SHADOW RES 1
BANKSEL GPIO
MOVF GPIO,W
MOVF PORT_SHADOW,W
MOVWF GPIO
; CLRWDT
SLEEP ; GOTO SLEEP
BANKSEL GPIO
MOVF PORT_SHADOW,W
MOVWF GPIO
CHECK BTFSC GPIO,3
GOTO CHECK
;DEBOUNCE DELAY
NOP
NOP
NOP
NOP
SLEEP
BANKSEL GPIO
thanks a lot
regards
