2camjohn said:It does seem simple just to forget the regulator, and as you say it wont break my solenoid, which is good.
But my circuit is designed to be left connected to the battery as it is being charged, so I need to protect my circuit (a pic and the 6v noid) from damage as the battery is given up to 12V during fast charge.
If i run the pic off the regulator, but the solenoid off the battery it is allright to put 12v across the battery as long as i dont turn my solenoid on..right?
Nigel Goodwin said:2camjohn said:It does seem simple just to forget the regulator, and as you say it wont break my solenoid, which is good.
Yes that's fine, but the voltage across the 6V battery won't reach anywhere near 12V, you charge a battery via some kind of current limiting device - this will effectively have 12V going in, and 6V coming out (actually a bit more than 6V as you charge the battery, it might reach 7.5V perhaps?).
2camjohn said:It does get quite high as it has some kind of fast charge initially. This is from the existing charger circuit which I havent measured.
2camjohn said:Can you tell me if putting a battery in series with a voltage regulator or zener diode will impede the ability to charge the circuit?
In my understanding a zener works by breaking down at the zener voltage, allowing current to flow thus stabilising the voltage, so wont all the excess current go though the zener instead of into the battery?
2camjohn said:Sorry for not being clear. I am trying :?
Sorry for my artwork too!
As the voltage from the charger increases wont the excess current go through the zener diode instead of into the battery?
