Voltage Divider Question.
shaneshane1
Hi just wondering if my calculations are correct on this subject?
I've made a voltage divider (in theory) with the output 2.1V from 12V
I used a 248R and a 52R with the output current at 20mA
is this equation correct?
12V/0.040A = 300R and 480mW
And
2.1V/0.040A = 52R and 84mW
300R - 52R = 248
R1 = 248R
R2 = 52R
And
300R - 52R = 248
R1 = 248R
R2 = 52R
That should give about 2.08V at the junction.
Whats the 2.1V going to be connected too.?
Hiya Shane,
Eh mate checkout this link https://electronics2000.co.uk/download.php#assistant
I've been using that calculator for years now and I'm sure you'll find it very handy too and the question you posted can be answered in no time by yourself.
Cheers Bryan
Nothing, its just some theory!
but i would say a 20mA LED with a forward voltage of 2.1V
bryan1 said:
Hiya Shane,
Cheers Bryan
Thanks for the link!!!
hi shane.
That could be a problem, normally you would not connect a resistor in parallel with a LED. Work out the currents in the LED and 52R..?
ericgibbs said:
hi shane.
This is what i am having trouble with!
The reason i put 40mA in the equation for R1 and R2 is because i though the current would halve at the center of the resistor's equaling to 20mA?
hi shane,
If you use a single 560R resistor from 12Vdc, allowing a 2.1Vfwd across the LED, that should give about 17mA.
The current does not change at the junction of the two resistors if there is no load. They will both carry 40mA. If there is a load at the junction then it will depend upon the resistance of the load in relation to the equivalent resistance at the resistor junction (look up Thevenin's Theorem).
An LED limits its own voltage. It just needs a series resistor to limit its current.
Thanks!!! :D
