Hello forum, I need to step down 24 volt DC to 3.2 volt to drive a bicyle LED tail light. Current drawn from light is 19ma which should be 169 ohms at 3.2 volts. Voltage is supplied from two 12v battries. When fully charged voltage is around 27v so i will design for that voltage.
Making R1 5k and R2 670 should get me 3.2 volt at the junction. When factor in the 169 ohm resistance of the load, the output voltage will drop to 709.6mv due to R2 and the load now in parrallel.
My question is should i design the circuit to output 3.2 volt while the load is connected or 3.2 volt with no load connected.
Chaning R1 to 1k should give me 3.2v when the load is connected but 10.8v when no load is connected.
When i experiment with dry cell battries almost no voltage is lost when the load is connected. Now i curious to know why.
