2PAC Mafia
I´m trying to repair this monitor. I leave the service manual which I found at Internet:
http://www.restoretronic.com/descargas/Viewsonic VG150 service manual.pdf
At the moment to follow my explanation you should check page 30 where is Power system schematic.
The problem is the monitor is not switching on. I saw a capacitor bulged so I was testing them at power supply circuit. I found C01, C12, C110, C118, C131, C132, C134, C135 damaged so I replaced them.
After that I saw 12V were not coming through the IC18. I found the ON/OFF switch damaged, I replaced it.
After that I saw how it tryes to run at pin 8 of IC18 but it stops again so I removed IC18 and I saw gate signal there is correct so ON/OFF circuit works.
I removed the IC22 and then I have 12V at pin 8 of IC8, I also have 5V at C131. The problem is I don´t have any power at C134.
I found an error at schematic at R112 which instead of that position is between D15 anode and pin 5 IC20. So if I measure at pin 5 of IC20 I have 0,6V and at pin 4 I have 0V, at pin 2 I have 0V. I guess I should measure 5V at pin 2, isn´t it?
Do you think if I remove IC22 could have any relationship? I don´t think so and I did that to isolate the problem, I expected to measure 5V at C131 and 5V at C134 but then I saw C134 is missing. Now I´m focused at this part of circuit to get the VLCD.
What do you think?
What do you think?
