Video Output
Teaius
Hello
I have a computer with a NVIDIA geforce fx go5200 graphics card.
I want to connect the output to the TV via a 4 pin S-Video cable. Unfortunatelly the card's output has 6 pin, it looks like exacly as the keyboard input and PS/2 mouse input.
I can't find 6 pin to 4 pin adapter for svideo, I only can find 7 pint to (4 pin svideo+RCA) adapters so I decided to do it myself using an old keyboard. Do anybody know how should I connect the pins between the output and 4 pin svideo and if I would need to use extra components like capacitors etc.?
Thank you.
just after a quick google; **broken link removed**
If you wanted to make one, just look, for pinous, and wire it up.
Then just hook up an rca connector to the composite pins (the outside is ground, i think).
I wanted to do it with s-video, my first idea was to use an old mouse and keyboard, cutting the cables and joining them correctly. Finally decided to do it with an old unused male-female PS/2 cable, because with mouse and keyboard some pins were missing.
Thank you for your replies.
