Vcc vs Vss
banh
I've seen some schematics and see some pins using Vcc, while others Vss. What's the difference between two?
if that is what the maximum voltage of the chip/part is, then yes
What is diffrence between Vss and Vs
In L298 motor contrl IC there r pins with Vs Supply Voltage and Vss Logic Supply Voltage so can u tell me what is differnce between thm.....
Salam Samad, welcome to the forum.
it'll be very advisable to open a new thread for your question but since you're new here it's okay.
Vs is for the motor power up, a range of 2.5-46V
Vss is the logic circuitry supply. Only 4.5-5V is needed, which can be derived from an LM7805.
