variable resistance controlled by voltage
pigrider
the idea is very simple. i have a sequencer that puts out 0-10 volts. i would like this sequencer to control a machine with potentiometer knobs. so variable volts controlling variable resistance. the volts are already there i just need a circuit to replace the knobs/pots.
any help would be greatly appreciated. my electronics knowledge is very limited so please explain thoroughly.
The answer to your problem is not that simple.
You could have a servo connected to a pot or go for the electrical approach.
I got as far as designing the block diagram for an electronic load resistor by using an analogue multiplier configured as a divider connected to a MOSFET. The divider monitors the voltage and current across the divider and adjusts the gate voltage to keep the resistance constant, i.e R=V/I.
What value resistor do you require?
What does the potentiometer control?
It's probably easier to integrate the control directly into the maching rather than using an electronic pot.
You can buy digital pots but I don't think they would be any use here as you want it to be voltage controlled.
the pots are on a reel to reel machine that plays music. i dont know the resistances off hand but can get them if it would help.
No, those pots respond to SPI signals or some other digital signals...not analog ones. Sounds like the circuitry inside an RC servo is similar to what you need (the way it works). I suppose you could just use a uC with an ADC to read the voltage and then control a digital pot...but that seems to not be as simple as you want.
