Hey,
I have a program that needs to be tested, it's an LED tachometer which runs 5 LED's depending on the input signal (0-5V) and it also tests for Oil pressure and Water temperature. If those two values are below or above a certain value, an LED each will come on.
I need to test the program output, but I don't know how to do this without the PIC (16F88) to test it on. Is there any program that can take an input and give me the programs output?
Also, when using the A/D converts, with a 4Mhz clock, setting the A/D to the interal clock of the A/D will be ok?
Here is my code if anyone wants to look over it. Thanks a lot!
; Title: "PIC Dash Controller"
; Date; April 7th, 2007
;REVIEW A/D CONVERSION CLOCK SETTING
list p=16F88
include "p16F88.inc"
errorlevel -302
__CONFIG _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF & _INTRC_IO
; Initializations
Word equ 0x30 ;general memory
; System initialization
org 0x0000
goto SYSTEMINIT
nop
nop
nop
SYSTEMINIT clrf PORTB ;clear contents of PORTB, making it 0
bsf STATUS,RP0 ;select bank 1
bsf OSCCON,6 ;Set oscilator to 4Mhz
bsf OSCCON,5
movlw 0x07
movwf CMCON ;Turn off Comparators
movlw b'00000000' ;set PortB all outputs
movwf TRISB
movlw b'11111111' ;set PortA all inputs
movwf TRISA
movlw b'00000111' ;sets RA0-RA2 to A/D inputs
movwf ANSEL ;
bcf STATUS,RP0 ;select bank 0
;Set ADCON1
bsf STATUS,RP0
movlw b'10000000' ;right justified, no clock divide, Vdd and Vcc as reference
movwf ADCON1
bcf STATUS,RP0
; Main Program
START call INIT_AN0 ;initialize AN0
call READ ;read the input of AN0
goto TACHRESULT ;find out tach result
TESTOIL call DELAY
call INIT_AN1 ;initialize AN1
call READ ;read the input of AN1
goto OILRESULT ;find out oil pressure result
TESTWATER call DELAY
call INIT_AN2 ;initialize AN2
call READ ;read the input of AN2
goto WATERRESULT ;find out water temperature result
LAST call DELAY
goto START
; A/D Initializations
INIT_AN0 movlw b'11000001' ;setting AN0 for tachometer sensor
movwf ADCON0 ;move into ADCON0
nop
nop
return
INIT_AN1 movlw b'11001001' ;setting AN1 for water temperature
nop
nop
return
INIT_AN2 movlw b'11010001' ;setting AN2 for oil pressure sensor
nop
nop
return
; Read in the analog input and convert to digital
READ call DELAY ;small delay for A/D aquisition time.
bsf ADCON0,GO_DONE ;initiate conversion
ADCDONE btfsc ADCON0,GO_DONE
goto ADCDONE ;wait for ADC to finish
movf ADRESL,W ;move results from ADRESL register to W
movwf Word ;move value from W to memory named Word
bcf STATUS,RP0 ;switch to bank 0
movf ADRESH,W ;move results from ADRESH register to W
movwf Word+1 ;move value from W to memory named Word and add 1
nop
nop
nop
return
; Results (Volts)
; Tach - X < 1 - 0 LED
; - 1 < X < 1.8 - 1 LED - RB0
; - 1.8 < X < 2.5 - 2 LED's - RB0, RB1
; - 2.5 < x < 3.3 - 3 LED's - RB0, RB1, RB2
; - 3.3 < x < 4.1 - 4 LED's - RB0, RB1, RB2, RB3
; - x > 4.1 - 5 LED's - RB0, RB1, RB2, RB3, RB4
; Oil - 0.9 < x < 3.9 - LED on - RB5
; Water - x < 1 - LED on - RB6
;Testing for x < 1
TACHRESULT movlw low(0x00cc) ; load W with value of low 0x00cc
subwf Word,W ; subtract value in file Word, with value in W
movlw high(0x00cc) ; load W with value of 0x00cc
btfss STATUS,C ; check to see if bit "C", in Status is set.
movlw high(0x00cc)+1 ; load W with value high 0x00cc and add 1
subwf Word+1,W ; subtract value in file Word, with value in W
btfss STATUS,C ; carry clear if word is less than 0x00cc
goto TESTOIL ; if below 1V, no LEDs on, check oil
;Testing for 1 < x < 1.8
TESTRB0 movlw low(0x0170) ; load W with value of low 0x0170
movlw high(0x0170) ; load W with value of 0x0170
movlw high(0x0170)+1 ; load W with value high 0x0170 and add 1
btfss STATUS,C ; carry clear if word is less than 0x0170
goto TESTRB0H
goto TESTRB1
TESTRB0H movlw low(0x0170) ;subtract low of 1.8 from Word
subwf Word,F ;put result into Word
movlw high(0x0170) ;subtract high of 1.8 from Word + 1
subwf Word+1,F ;put result into Word+1
movlw low(0x00cd)
subwf Word,W
movlw high(0x00cd)
btfss STATUS,C
movlw high(0x00cd)+1
subwf Word+1,W
btfsc STATUS,C ; carry set if word is greater or equal to 0x00cd
goto RB0_ON
;Testing for 1.8 < x < 2.5
TESTRB1 movlw low(0x01ff) ; load W with value of low 0x01ff
movlw high(0x01ff) ; load W with value of 0x01ff
movlw high(0x01ff)+1 ; load W with value high 0x01ff and add 1
btfss STATUS,C ; carry not set if word is less than 0x01ff
goto TESTRB1H
goto TESTRB2
TESTRB1H movlw low(0x01ff) ;subtract low of 1.8 from Word
movlw high(0x01ff) ;subtract high of 1.8 from Word + 1
movlw low(0x0171)
subwf Word,W
movlw high(0x0171)
btfss STATUS,C
movlw high(0x0171)+1
subwf Word+1,W
btfsc STATUS,C ; carry set if word is greater or equal to 0x0171
goto RB1_ON
;Testing for 2.5 < x < 3.3
TESTRB2 movlw low(0x02a3) ; load W with value of low 0x02a3
movlw high(0x02a3) ; load W with value of 0x02a3
movlw high(0x02a3)+1 ; load W with value high 0x02a3 and add 1
btfss STATUS,C ; carry clear if word is less than 0x02a3
goto TESTRB2H
goto TESTRB3
TESTRB2H movlw low(0x02a3) ;subtract low of 1.8 from Word
movlw high(0x02a3) ;subtract high of 1.8 from Word + 1
movlw low(0x0200)
subwf Word,W
movlw high(0x0200)
btfss STATUS,C
movlw high(0x0200)+1
subwf Word+1,W
btfsc STATUS,C ; carry set if word is greater or equal to 0x0200
goto RB2_ON
;Testing for 3.3 < x < 4.1
TESTRB3 movlw low(0x0346) ; load W with value of low 0x0346
movlw high(0x0346) ; load W with value of 0x0346
movlw high(0x0346)+1 ; load W with value high 0x0346 and add 1
btfss STATUS,C ; carry clear if word is less than 0x0346
goto TESTRB3H
goto TESTRB4
TESTRB3H movlw low(0x0346) ;subtract low of 1.8 from Word
movlw high(0x0346) ;subtract high of 1.8 from Word + 1
movlw low(0x02a4)
subwf Word,W
movlw high(0x02a4)
btfss STATUS,C
movlw high(0x02a4)+1
subwf Word+1,W
btfsc STATUS,C ; carry set if word is greater or equal to 0x02a4
goto RB3_ON
;Testing for x > 4.1
TESTRB4 movlw low(0x0347)
subwf Word,W
movlw high(0x0347)
btfss STATUS,C
movlw high(0x0347)+1
subwf Word+1,W
btfsc STATUS,C ; carry set if word is greater or equal to 0x0347
goto RB4_ON
goto TESTOIL ;go back to main program, tach test is done
;Testing Oil for 0.9 > x and x > 3.9
OILRESULT movlw low(0x00b8) ; load W with value of low 0x00b8
movlw high(0x00b8) ; load W with value of 0x00b8
movlw high(0x00b8)+1 ; load W with value high 0x00b8 and add 1
btfss STATUS,C ; carry clear if word is less than 0x00b8
goto OIL_ON
movlw low(0x031d)
subwf Word,W
movlw high(0x031d)
btfss STATUS,C
movlw high(0x031d)+1
subwf Word+1,W
btfsc STATUS,C ; carry set if word is greater or equal to 0x031d
goto OIL_ON
goto TESTWATER ;go back to main program, oil testing is done
;Testing for x < 1
WATERRESULT movlw low(0x00cc) ; load W with value of low 0x00cc
goto WATER_ON ;if below 1V, water LED on
goto LAST ;if it is above 1V, return to main program
; Subroutines
RB0_ON movf PORTB,W ;move contents of PORTB into W
andlw b'11100001' ;AND literal with W, store in W
movlw PORTB
goto TESTOIL
RB1_ON movf PORTB,W ;move contents of PORTB into W
andlw b'11100011' ;AND literal with W, store in W
movlw PORTB
goto TESTOIL
RB2_ON movf PORTB,W ;move contents of PORTB into W
andlw b'11100111' ;AND literal with W, store in W
movlw PORTB ;move the result from W into PORTB
goto TESTOIL
RB3_ON movf PORTB,W ;move contents of PORTB into W
andlw b'11101111' ;AND literal with W, store in W
goto TESTOIL
RB4_ON movf PORTB,W ;move contents of PORTB into W
andlw b'11111111' ;AND literal with W, store in W
goto TESTOIL
OIL_ON movf PORTB,W ;move contents of PORTB into W
andlw b'10111111' ;AND literal with W, store in W
goto TESTWATER
WATER_ON movf PORTB,W ;move contents of PORTB into W
andlw b'11011111' ;AND literal with W, store in W
goto START
DELAY movlw 0x05 ;will delay W*8 cycles including the call/return
DELAYW addlw 0xff ;add -1 to W
btfsc STATUS,Z ;=zero?
goto DONEDELAY ;if zero, finish delay
nop ;delay a bit
goto $+1
goto DELAYW ;go around again
DONEDELAY return
end
