Using Schottky Rectifiers
Scubasteve
Hey all,
I have been wandering about using some schottky in a bridge rectifier because of their much lower forward drop (350mV typical) voltage. Is there any problems with using these diodes in this application?
Also, I have designed a voltage quadrupler with ~1000uF capacitors (these were found to be optimal) with silicon diodes, can I expect this to work okay with schottky diodes also? I am just leary that I am missing a spec or something that would render these useless, but I am probably wrong.
I guess people don't use these often for such things because of their expense over regular silicon diodes..
Anyone have any insight?
Steve
Using Schottky's in a bridge is an expensive way of doing it.......but as you say lower forward v drop, but is it really necessary to go this far ?
Schottky's may be faster but this attribute isnt really needed if you are just rectifying std 50/60 hz.......
I also believe using them in such a way gives rise to extraneous radiation(RF spikes) caused by their fast switching action........something I read along the way, a while back, so they need extra caps across them to alleviate this to some degree.....
My opinion, stick with the Silicon counter part, cheaper :)
As for the multiplier, yeah should work, again costly.
Hi Chippie,
Thanks for your reply, it is good to know that these will work for my application. I need the low forward voltage dtop, I am actually getting a good regulated 5Vdc from a 6.3Vac output on a transformer.. (0.35mV drop X 2 + 300mV LDO Regulator at 3A)
I know that the transformer is at its RMS value, but I want to be safe.. The manufacturer actually didn't specify voltage under no-load and load, should I assume that it can put out 6.3VacRMS under its full rated 1.6A load?
Thanks again!!,
Steve
"should I assume that it can put out 6.3VacRMS under its full rated 1.6A load? "
If that is what the manufacturer claims then it should deliver the full rated output
