Using old Calculator's Solar Array
mahesh_jo
I am having some Solar Array's from old solar powered calculators. Anybody has any idea about utilizing them?
Mahesh Joshi
Bhopal, India
For a start I should try measuring their output, generally solar calculators work on extremely low power - and the panels are correspondingly low outputs.
They are ok for VERY small current applications. Ie. don't try and drive a motor from them continuously :).
JB
You can run a LF pic from such a cell.
But then again, since there is only enough current for the pic, and not for other circuitry it becomes pretty useless (a pic on it's own hardly does something usefull :lol: )
you might be able to use it to trickle charge a battery which is then fed to whatever you want...
I used one to trickle charge a battery which powered a PIC, which was in sleep 99% of the time.
Solar-cell Uses
If it has enough voltage and current to light an LED, then shine the LED on the solar cell and you will have PERPETUAL MOTION! Ha-Ha.
there are many minature robotics people who use these cell, they charge up a capacitor and discharge through a pager vibration motor, examples are light following robots, be warned though - they walk extremly slowly!!! :?
