Using multiple regulators in a circuit?
Paleoneon
I'm making a circuit that will need both 12V and 5v rails. Can I put a couple of 7805 regulators in parallel for the 5V rail if I need more than amp or so of regulated 5V current?. The 12V source can supply plenty of current to the7805s.
It can be done but isn't recommended as it could be unstable and oscillate.
It's much better to use a series pass transistor, see the datasheet for details.
You can use LT1083/1084/1085 regulators, but you can't use ceramic output caps with them.
Check this article from EDN.
Or, you can use multiple 7805s with a small (e.g., 1 ohm) resistor in series between EACH output lead and the 5v bus. That small resistor will allow a small voltage drop between disagreeing regulators and allow them to better share the current at the cost of adding a little "softness" to the supply.
Dean
