Using code for a 16f873 on a 16f876
I have code for a project that is written for a 16F873 and want to use a 16F876 instead. What do I have to change to make it work, just the INC file reference? I actually tried just doing that and it compiled successfully but I'm having problems with the circuit. Thanks
It might be best to describe the problems you are having with the project/circuit first, rather than leave things subject to guesswork.
There are only very slight differences between the .INC's as essentially, both devices are the same, apart from more-or-less double the available memory on the '876. The differences are with RAM locations and the range of memory when CP is enabled.
A few Q's:
What are you expecting to observe and are not doing so?
Are you sure that the code works perfectly on the '873?
Have you built the circuit correctly?
How are you building the .HEX.... MPLAB, MPASMWIN etc.?
Are you building absolute, or relocatable code?
Can you provide a link to, or post the code here and wrap
 tags around it? ( [B]#[/B] on the reply box.)
Regards.
I've run '870 code on a '876 with no changes at all if thats any use.
It's supposed to be a digital speedometer and odometer. Every thing should start at zero when powered up. What's happening is the speedometer displays only light up. When the bases of the controlling transistors are disconnected the odometer displays will light up. Even at that all segments are lit. By accident I bumped the crystal off the bread board and I observed the odometer displays would all display the same character and one digit would be off. If I re-insert the crystal and remove it again it will display a different character with a different display off.
No, but my next step is to purchase a '873 and go from there. I had the '876 in stock and wanted to see what would happen. Obviously I don't want to waste too much time without knowing if it works or not with the '873.
With the exception of a 20 MHz crystal instead of the 10 MHz crystal. I know that will affect the timing functions but I wanted to see how it worked overall. Also, last night I found out the transistors driveing the anodes of the displays are NPN where I thought they were PNP (the circuit is from a Russian site, and some of does not translate well). I made an assumption that was obviously wrong. That in itself may explain what I'm seeing.
MPASMWIN. I changed the include files to reference the 876. It compiled succesfully but did generate an error file when compiled for the 876 and the 873
I don't know, I a newbie to code and micro controllers.
 tags around it? ( [B]#[/B] on the reply box.)[/QUOTE]
Schematic
[ATTACH=CONFIG]66024[/ATTACH]
The code is too long to post here, but if you go to the site
[I]**broken link removed**[/I]
Its the code under the schematic that's shown above.
Or the translated page is [I]**broken link removed**[/I]
Looking at the translated page, here:
there is some additional text, below in italic, possibly indicating some uncorrected errors on the schematic you have posted.
Diagram of the BMA for the speedometer-odometer "in one bottle. In the manufacture of the surfaced error:
1. the values you want to change. ..
R1 = 200 Ω, R2 = R3 = 680 ohm, 1, 5kOm, R4 = 3, 3Com.
2. a peak 11 and 21 inputs inverted.
The Russian NPN transistors for the displays (KT646) have a cross-ref to 2SC495 or 2SC496 & BD139.
They might be overkill, since they are 1000mA max. You may be able to use something like BC337, but I'd prefer someone more knowlegeable to confirm this.
If you can get the NPN transistors (check pinouts) sourced & check/resolve the possible errors listed above, you have a better starting point.
Regards.
Good News!
I wired up the circuit with some general purpose NPN transistors and it works!!!
As Mickster pointed out the errors that were listed pins 11 and 21 are reversed. When the circuit is powered up all segments are on briefly as a lamp test and then the speedometer resets to zero and the odometer defaults to the total distance count. Pressing s1 changes the odometer to a re-settable trip counter in the form of "000.00" If I put a 500Hz signal on the input the speedometer displays "231" and the odometers count up. Best of all, it retains the odometer count when powered off.
So I guess the answer to my original question is (in my case at least) yes. I do need to make some changes though...
First, I need to re-code it to work with my sensor which pulses 8, 000 times per mile. So at 100 mph that's a frequency of 222.222 Hz. How do I adjust the counter?
Second, the displays are very dim, I'm guessing from being multiplexed. How can I get them to full brightness?
Finally, I would like the main odometer needs to increment by 1 mile and the trip odometer needs to be in the form of "0000.0" and increment by 0.1 miles. What part of the code would be responsible for that?
After an evening of copying & pasting the Russian comments into Google, here is a roughly translated .asm listing for the project:
             ;*   2 in 1 SPEEDO-ODO-METER PIC 16F873   *
; 10 MHz quartz crystal
; sensor 6 pulses per meter
 list p=16F873
 #include
 __config _CP_OFF & _WDT_OFF & _PWRTE_ON & _HS_OSC & _LVP_OFF
; constants
RCSwitch equ 1    ; RC1
RCPower  equ 0    ; RC0
RCButton equ 3    ; RA3
RCPoint  equ 4    ; RA4
; variables
; Number of active segment
INDNO equ 0x20
; Buffer display odometer digits in the form of combinations of segments
IND01 equ 0x21
IND02 equ 0x22
IND03 equ 0x23
IND04 equ 0x24
IND05 equ 0x25
IND06 equ 0x26
; Speedometer display buffer
INDS1 equ 0x27
INDS2 equ 0x28
INDS3 equ 0x29
; the main counter of the total range
tot_prev equ 0x2A
tor_k001 equ 0x2B
tot_k010 equ 0x2C
tot_k100 equ 0x2D
tot_001k equ 0x2E
tot_010k equ 0x2F
tot_100k equ 0x30
tot_001t equ 0x31
tot_010t equ 0x32
tot_100t equ 0x33
; an additional daily run counter
aux_prev equ 0x34
aux_k001 equ 0x35
aux_k010 equ 0x36
aux_k100 equ 0x37
aux_001k equ 0x38
aux_010k equ 0x39
aux_100k equ 0x3A
IPM      equ 0x3B
SCR_MODE equ 0x3C
BTN_MODE equ 0x3D
BTN_CNTR equ 0x3E
BTN_STAT equ 0x3F
cntr2    equ 0x40
iHCNT    equ 0x41
iLCNT    equ 0x42
cHCNT    equ 0x43
cLCNT    equ 0x44
PreDIG   equ 0x45
EspDIG   equ 0x46
DspDIG   equ 0x47
HspDIG   equ 0x48
; BTN_MODE - describes what happened to the button
;   00 - the button is located at the top
;   01 - push (move down)
;   11 - at the bottom
;   10 - drop (move up)
; SCR_MODE - specifies the procedure FILL_VB, than fill the video buffer
;   0 - total range of
;   1 - daily
;   2 - empty
;   3 - the word RESET
; program
        org     0x00
        goto    START
; recoding digits in the code 7-segment display
SEG7            ; in the counters is not the value itself, and (10 value)
  sublw d'010'  ; calculated value of
  andlw 0x0F    ; just in case
  addwf PCL,f
;         ebfdacg      zero bit in the segment lights
  retlw b'00000011' ;  0
  retlw b'10111011' ;  1
  retlw b'00100101' ;  2
  retlw b'10100001' ;  3
  retlw b'10011001' ;  4
  retlw b'11000001' ;  5
  retlw b'01000001' ;  6
  retlw b'10110011' ;  7
  retlw b'00000001' ;  8
  retlw b'10000001' ;  9
  retlw b'11110111' ; 10
  retlw b'10111111' ; 11
  retlw b'11111011' ; 12
  retlw b'11101111' ; 13
  retlw b'01111111' ; 14
  retlw b'11011111' ; 15
; enable calculation of the bit level to the number of active anode
ANOD_C
  andlw 0x07    ;just in case
  addwf PCL,f
;         123465       unit at the bit level lights
  retlw b'00000000' ;  0
  retlw b'10000000' ;  1
  retlw b'01000000' ;  2
  retlw b'00100000' ;  3
  retlw b'00010000' ;  4
  retlw b'00000100' ;  5
  retlw b'00001000' ;  6
  retlw b'00000000' ;  7
ANOD_A
  andlw 0x03    ;just in case
  addwf PCL,f
;              321  unit in the category of 1 bit of lights and hundreds of dozens of 2-3-units
  retlw b'00010000' ;  0
  retlw b'00010001' ;  1
  retlw b'00010010' ;  2
  retlw b'00010100' ;  3
START
        bcf     STATUS, RP0     ; bank 0
        bcf     STATUS, RP1
        clrf    T2CON
        clrf    TMR0
        clrf    TMR2
        clrf    INTCON
        clrf    PORTA
        clrf    PORTB
        clrf    PORTC
        bsf     STATUS, RP0     ; bank 1
        movlw   0x06            ; And on all legs tsirfu??????
        movwf   ADCON1
        movlw   b'00001000'
        movwf   TRISA           ; RA3 - button, the rest of the output
        movlw   b'00000001'
        movwf   TRISB           ; RB0 - sensor, the other output
        movlw   b'00000001'
        movwf   TRISC           ; RC0 - ignition, the other output
; include pull-up resistors, TMR0 to the internal clock with prescaler 16 (4 ms in the figure)
		movlw   b'01000011'
		movwf   OPTION_REG
; include TIMER2
        clrf    PIE1
        movlw   d'249'          ; with quartz 10 mhz system??? clock = Fosc/4 = 2,5 MHz, 0.4 ms
        movwf   PR2             ; period register TIMER2 = 250 clock = 100 microseconds per cycle
                                ; cycle = 100 ms * 1(PRE) * 1 (POST) = 100 ms
		bcf     STATUS,RP0     ; bank 0
        movlw   b'00000100'     ; none:7  (POST-1):6-3   On/Off:2  PRE: 1-0
        movwf   T2CON           ;          b0000 = 1:1     1=On     b00 = 1
        clrf    PIR1
        bsf     PORTC, RCSwitch
        call    READ_EEPROM
        movlw   d'10'
        movwf   HspDIG
        movwf   DspDIG
        movwf   EspDIG
        movlw   1                  ; was 8
        movwf   PreDIG
        movlw   9
        movwf   INDNO
        clrf    TMR0
        bcf     INTCON,T0IF  ; reset the timer
        call    PROLOG
        clrf    BTN_MODE
        clrf    SCR_MODE
        call    FILL_VB
        call    FILL_SPD
        movlw  d'23'            ; was d'37 'to 30 pulses / m
        movwf iHCNT
        movlw d'112'          ; was d'128 'for 30 pulses / m
        movwf iLCNT
        clrf    cHCNT
        movlw   1
        movwf   cLCNT
MAIN_LOOP
; check the power
        btfss   PORTC,RCPower; Off we go around, if 1
        goto    PowerDown
PowerRise
; dimensional check the timer
        btfsc   PIR1,TMR2IF  ; if 0 (no signal from TIMER2), by bypassing
        call    DO_TICK      ; and if 1, then go to increase the counter
; check the sensor
        btfsc   INTCON,INTF  ; if 0 (no signal from the sensor), from the bypass
        call    DO_INCR      ; and if 1, then go to increase the counter
; duplicate the state of the sensor
;        btfsc   PORTB,0
;        bsf     PORTA,5
;        btfss   PORTB,0
;        bcf     PORTA,5
; check the timer for dynamic display
        btfss   INTCON,T0IF  ; If the timer has finished counting, you're going to change the discharge
	goto    MAIN_LOOP    ;  otherwise, repeat the test in a loop
; anything below is executed 1 time 1.6 ms (at 10MHz)
        call    ChkButton    ; treatment of buttons
        call    ChAnod       ; switch the indicator bits
        goto    MAIN_LOOP
; check button, and respond
ChkButton
        rlf     BTN_MODE,f    ; each time BTN_MODE shift by 1 bit to the left
        bcf     BTN_MODE,0    ; and Write the bits
        btfss   PORTA, RCButton  ;   0, if the button at the top
        bsf     BTN_MODE,0       ;   1, if the bottom
        movf    BTN_MODE,w      ; then cut out the lower two bits
        andlw   3             ; and from them select the treatment option
        addwf   PCL,f         ;
        goto    Btn_UpUp      ;  00 - button has been and remains at the top (always depressed)
        goto    Btn_UpDn      ;  01 - moved from the top down (pressed)
        goto    Btn_DnUp      ;  10 - moved from the bottom up (released)
        goto    Btn_DnDn      ;  11 - has been and remains at the bottom (always pressed)
Btn_UpDn ; CLICK
        clrf    BTN_CNTR      ; when you click
        clrf    BTN_STAT      ; zero out counters retention time
        goto    Btn_UpUp
Btn_DnDn ; HOLD           continue to increase the counter
        incfsz  BTN_CNTR,f    ; when the counter reached the count of 256 (0.4 seconds)
        goto    TestSTATUS
        incf    BTN_STAT,f    ; reactions modify the code to lift buttons
TestSTATUS                    ; depending on the retention time
        btfss   BTN_STAT,2    ;  0, 1 , 2, 3   (0.4 to 0.8 to 1.2 to 1.6 sec)
        goto    Btn_UpUp
        decf    BTN_STAT,f    ; if the code has reached 4, then return it to the three
        bsf     SCR_MODE,1    ; change the display mode data in the display
        call    FILL_VB       ; Now for the WHOLE screen NOTHING
        goto    Btn_UpUp      ; for daily on-screen word RESET
Btn_DnUp ; RELEASED
        btfss   SCR_MODE,1    ; if there was a short jab
        goto    SwitchMode    ; we're going to switch the display mode
TestReset
        bcf     SCR_MODE,1    ; Kicks for a long???
        btfss   SCR_MODE,0    ; returned to normal operating mode indicator FULL / DAILY
        goto    ODOmode
        movf    IPM,w         ; and for the daily addition
        movwf   aux_prev      ; did reset discharges 000.00
        movlw   d'10'
        movwf   aux_100k
        movwf   aux_010k
        movwf   aux_001k
        movwf   aux_k100
        movwf   aux_k010
        movwf   aux_k001
        goto    ODOmode
SwitchMode                    ; switching mode indicator FULL / DAILY
        movlw   1
        xorwf   SCR_MODE,f
ODOmode                       ; restoration of the buffer indicator
        call    FILL_VB
Btn_UpUp                      ; if the button is always on top, there's nothing else to do
        return
FILL_SPD    ; portable numbers skrosti??? previous measurement in the video buffer
  movf    HspDIG,w
  call    SEG7       ; the output of hundreds of
  movwf   INDS1      ;
  movf    DspDIG,w
  call    SEG7       ; withdrawal of tens of
  movwf   INDS2
  movf    EspDIG,w   ; output units are always
  call    SEG7
  movwf   INDS3
  call    CLR_LEAD0  ; repay the zeros
  return
; filling the video buffer code segments
FILL_VB
  movfw  SCR_MODE    ; choose than to fill the buffer indicator
  andlw  b'00000011' ; depending on the value of SRC_MODE
  addwf  PCL,f
  goto   Fill_ODOM
  goto   Fill_TRIP
  goto   Fill_NONE
  goto   Fill_TEXT
Fill_ODOM            ; fill the buffer
  movfw tot_100t     ; figures the total range
  call  SEG7
  movwf IND01
  movfw tot_010t
  call  SEG7
  movwf IND02
  movfw tot_001t
  call  SEG7
  movwf IND03
  movfw tot_100k
  call  SEG7
  movwf IND04
  movfw tot_010k
  call  SEG7
  movwf IND05
  movfw tot_001k
  call  SEG7
  movwf IND06
  return
Fill_TRIP            ; numbers of daily run
  movlw b'11111111'  ; significant bit of the dark
  movwf IND01
  movfw aux_100k
  call  SEG7
  movwf IND02
  movfw aux_010k
  call  SEG7
  movwf IND03
  movfw aux_001k
  call  SEG7
  movwf IND04
  movfw aux_k100
  call  SEG7
  movwf IND05
  movfw aux_k010
  call  SEG7
  movwf IND06
  bcf   IND04,0     ; put a sign "point of need" for the second discharge
  return
Fill_TEXT           ; the word RESET
;         ebfdacg   zero lights
  movlw b'11111111'
  movwf IND01
  movlw b'01000111' ;  С?
  movwf IND02
  movlw b'01000001' ;  B?
  movwf IND03
  movlw b'00010101' ;  Р?
  movwf IND04
  movlw b'00000011' ;  0?
  movwf IND05
  movwf IND06
  return
Fill_NONE           ; put out all the bits
  movlw b'11111111' ; a prolonged retention
  movwf IND01       ; button in the full path
  movwf IND02
  movwf IND03
  movwf IND04
  movwf IND05
  movwf IND06
  return
ChAnod
;Service indication (after each complete cycle of the reference clock 1.6 ms x 6 bits = 100 Hz)
        movlw   IND01-1
        movwf   FSR
        movlw   0x03
        andwf   PORTC,f      ; switched off discharge
        movlw   0xF8
        andwf   PORTA,f
        bsf     PORTA, RCPoint
        movlw   9            ; calculation of the numbers next level
        decfsz  INDNO,f      ; cyclically
        movfw   INDNO        ;   9 8 7 6 5 4 3 2 1 and around 9 8 7 6 5 ...
        movwf   INDNO
        addwf   FSR,f        ; load combination of cathodes
        movfw   INDF         ; to the next level
        movwf   PORTB
        movfw   INDNO
        sublw   6
        btfss   STATUS,C
        goto    ANOD_SPD
        btfss   INDF,0         ; if the sign of "point of need" is reset, then turn round
        bcf     PORTA, RCPoint ; including the point
        movfw   INDNO
        call    ANOD_C
        iorwf   PORTC,f        ; include the following anode discharge
        return
ANOD_SPD
        call    ANOD_A
        iorwf   PORTA,f        ; include the following anode discharge
        return
; came from the tick timer dimensional (was 100 ms)
DO_TICK
  bcf     PIR1,TMR2IF        ; reset the interrupt flag
  decfsz  cLCNT,f
  return
  ; over the next small counter
  movf    cHCNT,f            ; check the big count
  btfsc   STATUS,Z           ; if cHCNT=0
  goto    ResetCNTS          ; it goes counter to initialize a new count
  movf    iLCNT,w
  decfsz  cHCNT,f            ; cHCNT=cHCNT-1
  movlw   0                  ; if <>0, то cLCNT=256
  movwf   cLCNT              ;       =0,         =iLCNT
  return
ResetCNTS
  movf    iHCNT,w
  movwf   cHCNT              ; cHCNT=iHCNT
  clrf    cLCNT              ; cLCNT=256
  call    FILL_SPD
;  call    FILL_VB
  ; reset for the new measurement
  movlw   d'10'
  movwf   HspDIG
  movwf   DspDIG
  movwf   EspDIG
  movlw   1                  ; was 8
  movwf   PreDIG
  return
; Increment counters
DO_INCR              ;                                  123 456             789    10
  movlw  d'10'       ; 10 bits for a full run 999,999 kilometers (see). 999 m + IPM (not visible)
  movwf  cntr2
  movlw  tot_prev-1
  call   CH_CNTR     ;                           123     45          6     7
  movlw  7           ; 7 places to 999 km daily .99 (visible) 9m + IPM (not visible)
  movwf  cntr2
  movlw  aux_prev-1
  call   CH_CNTR
  movlw  4           ; first 3 digits speedometer
  movwf  cntr2
  movlw  PreDIG-1
  movwf  FSR
  movlw  1              ;  was 8
  call   CH_LOOP
  call   FILL_VB     ; updated codes cathodes in the buffer indicator
;  call   FILL_SPD
  bcf    INTCON,INTF ; external interrupt flag is dropped
  return
CH_CNTR
  movwf  FSR
  movf   IPM,w       ; for pre-Meter IPM (impacts per meter)
CH_LOOP
  incf   FSR,f
  decfsz INDF,f
  return
  movwf  INDF
  movlw  d'10'       ; for all the other bits of the counter
  decfsz cntr2,f
  goto   CH_LOOP
  return
PowerDown
  call WRITE_EEPROM  ; write counters in non-volatile memory
; WRITE the word in the buffer indicator
  movlw b'10100001' ;  3?
  movwf IND01
  movlw b'00010001' ;  A?
  movwf IND02
  movlw b'00010011' ;  П?
  movwf IND03
  movlw b'00001011' ;  И?
  movwf IND04
  movwf IND05
  movlw b'01001001' ;  Ь?
  movwf IND06
SDeadLoop
  movlw  D'255'
  movwf  cntr2
DeadLoop
  btfss  INTCON,T0IF
  goto   DeadLoop
  call   ChAnod
  decfsz cntr2,f
  goto   DeadLoop-1
; goto SDeadLoop
  btfsc  PORTC,RCPower  ; If power is not restored (0), bypassing the return
  goto   PWRRestoted    ; If you restore (1), then return
; disconnect all power
  bcf    PORTC,RCSwitch
  goto   SDeadLoop
PWRRestored
  call   FILL_VB
  bsf    PORTC,RCSwitch ; will again include
  goto   PowerRise
READ_EEPROM  ; load counters from the non-volatile memory
   movlw  d'18'
   movwf  cntr2
   movlw  tot_prev
   movwf  FSR
RD_LOOP
   movfw  FSR
   addlw  -tot_prev
   bsf   STATUS,RP1  ; bank 2  - at the inlet bank 0
   movwf EEADR
   bsf   STATUS,RP0  ; bank 3
   bcf   EECON1,EEPGD
   bsf   EECON1,RD
   bcf   STATUS,RP0  ; bank 2
   movfw EEDATA
   bcf    STATUS,RP1 ; bank 0
   movwf  INDF
   incf   FSR,f
   decfsz cntr2,f
   goto   RD_LOOP
   return
WRITE_EEPROM  ; preservation of the counters in the nonvolatile memory
   movlw  d'17'
   movwf  cntr2       ; cntr2 = 15
   movlw  tot_prev
   movwf  FSR         ; FSR = @tot_prev    = RAM address registers
WR_LOOP
   movfw  FSR
   addlw  -tot_prev   ; W = 0, 1, ... , 14 = EEPROM address registers
;  The procedure for writing bytes to the EEPROM
   movwf  EEADR       ; Transferring the W in EEADR
   movfw  INDF        ; Write the contents of W register RAM
   movwf  EEDATA      ; Из W в EEDATA???????
   bcf    EECON1,EEPGD; choose EEPROM
   bsf    EECON1,WREN ; allow entry
   movlw  h'55'       ; **   Compulsory **
   movwf  EECON2      ; **   procedure  **
   movlw  h'AA'       ; **   without    **
   movwf  EECON2      ; **   comments   **
   bsf    EECON1,WR   ; The command to start recording
   btfsc  EECON1,WR   ; loop, waiting for the completion of recording
   goto   $-1         ; repeat
   bcf    EECON1,WREN
   bcf    STATUS,RP1
   incf   FSR,f       ; FSR = @tot_prev +1, +2, ..., + 15
   decfsz cntr2,f
   goto   WR_LOOP     ; repeat 17 times
   return
CLR_LEAD0
   movf   HspDIG,w
   sublw  d'10'
   btfss  STATUS,Z
   return
   movlw  b'11111111'
   movwf  INDS1
   movf   DspDIG,w
   sublw  d'10'
   btfss  STATUS,Z
   return
   movlw  b'11111111'
   movwf  INDS2
   return
PROLOG
        clrf    IND01
        clrf    IND02
        clrf    IND03
        clrf    IND04
        clrf    IND05
        clrf    IND06
        clrf    INDS1
        clrf    INDS2
        clrf    INDS3
        clrf    cLCNT
        movlw   3
        movwf   cHCNT
PRO_LOOP
        btfss   INTCON,T0IF
	goto    PRO_LOOP
        call    ChAnod
        decfsz  cLCNT,f
        goto    PRO_LOOP
        decfsz  cHCNT,f
        goto    PRO_LOOP
    return
 org 0x2100
; numbers by default (remain in place! order is important!)
; in the EEPROM are stored as a 10-s
; total range of
eet_prev de d'06'   ; preliminary invisible
eet_k001 de d'10'-0
eet_k010 de d'10'-0
eet_k100 de d'10'-0 ; displayed below the level
eet_001k de d'10'-0 ; 1 км
eet_010k de d'10'-0
eet_100k de d'10'-0
eet_001t de d'10'-5
eet_010t de d'10'-9
eet_100t de d'10'-0 ; 100 000 км
;daily mileage
eea_prev de d'06'   ; preliminary invisible
eea_k001 de d'10'-0
eea_k010 de d'10'-0 ; 10 м
eea_k100 de d'10'-0
eea_001k de d'10'-0 ; 1 км
eea_010k de d'10'-0
eea_100k de d'10'-0 ; 100 км
; the number of pulses at 1 meter
eeIPM    de d'06'
  end				;end of program
The eyes are a bit tired now, so I'll let someone else have a look for where the necessary changes are needed.
Regards.
I've made some progress. I've moved the decimal point in the trip counter and I've changed some of the Russian characters displayed to English words. Not really important to the operation but It's progress for me just in figuring some of this stuff out. I'm going to start a new thread to try to figure out some of the more important stuff.
