bigal_scorpio
Active Member
Hi to all,
I am having a small problem with a circuit I have made that dims an LED display in the car.
I designed the circuit to dim the LED at night when I put the lights on thinking when I switch the lights on that the +12v from the light circuit would hold on a transistor which in turn dims the LED until the lights are turned off, simple eh! No!
I have now found that the lights are controlled by PWM (well the dash lights anyway - which are easy to access) which has the effect of pulsing the LED.
So does anyone know if it would be OK to put an electrolytic cap from the lights wire to ground or would this effect the operation of the cars PWM, or even damage it?
Otherwise is there a simple way of safely converting a PWM signal to logic on or off?
Thanks for looking........Al
