Hi there!
I'm starting to work on my first real electronics project, which is to build my own ultrasonic range finder. I've figured out that I need to use piezoelectric transducers, and I think that I more or less understand the basic principles from reading here.
Sensing pulses:
The transducer has a piece of neutrally charged but polarized material which becomes polarized when it's mechanically distorted. The polarizations can be measured as a voltage, and so the transducer can be used to sense incoming sound waves, as the waves distort the material slightly.
Transmitting pulses:
When a voltage is applied over the terminals of the polarized material, the molecules will move to align themselves with the electrical field, and the material will mechanically distort. By reversing the direction of the electrical field the material will distort in the opposite direction, and you can thereby generate a sound wave pulse train.
Would you agree on that simple explanation?
So my question is: Is it possible to use a single piezoelectric element to both generate mechanical vibration (i.e., the ultrasonic wave) and sense waves that have been reflected from nearby surfaces?
Thank you for helping me understand this basic fact .
-Halfdan
Sensing pulses:
-Halfdan
