Usb PC camera data rate speed
khgsm2007
Hi all
I want to ask about the USB data rate speed " Range" between the pc cam and the Pc in order to get alive photo on PC
BR
You have 3 basic speed settings for USB
1. normal speed 1.5Mbps (USB 1.1, USB 2.0)
2. full speed 12Mbps (USB 1.1, USB 2.0)
3. high speed 480Mbps (USB 2.0)
"range" if you are asking about speed range, it is 1.5 - 480Mbps depending on the standard, if you are asking about "length", max cable length is 5m without repeaters (hub is also repeater) and IIRC 25m total length (with repeaters).
for realtime video stream 1.5Mbps is enough for some basic quality, for broadcast quality you need 4-40Mbps depending on the "action" and depending on the encryption, resolution etc.
Check out the following link for more info about usb:
USB 2.0, Hi Speed USB FAQ
