include 18f14k50
-- This file is the setup for my homebrew, 18f14k50 board
-- Currently it is a bare board, with just a PIC and a couple of headers
-- A 12 MHz external crystal and 15pf caps connected to OSC1/2
-- pin 17 (Vusb) with a 220 nF capacitor to the ground
-- The connection between PC and the 18F14k50
-- +5v to power the board (don't forget 100nf decoupling cap
-- data- wire to pin 18 (D-)
-- data+ wire to pin 19 (D+)
-- ground wire to the Vss of the PIC
-- even though the external crystal is 12 MHz, the configuration is such that
-- the CPU clock is derived from the 96 Mhz PLL clock (div2), therefore set
-- target frequency to 48 MHz
pragma target clock 48_000_000
-- fuses
pragma target CPUDIV P1 -- NO_CPU_SYSTEM_CLOCK_DIVIDE
pragma target USBDIV P1 -- USB_CLOCK_COMES_DIRECTLY_FROM_THE_OSC1_OSC2_OSCILLATOR_BLOCK_NO_DIVIDE
pragma target OSC HS
pragma target PLLEN P4 -- OSCILLATOR_MULTIPLIED_BY_4
pragma target FCMEN DISABLED
pragma target IESO DISABLED
pragma target PWRTE DISABLED -- power up timer
pragma target BROWNOUT DISABLED -- no brownout detection
pragma target VOLTAGE V30 -- brown out voltage
pragma target WDT DISABLED -- no watchdog
pragma target WDTPS P32K -- watch dog saler setting
pragma target MCLR EXTERNAL -- external reset
pragma target LVP DISABLED -- no low-voltage programming
pragma target XINST ENABLED -- extended instruction set
pragma target DEBUG DISABLED -- background debugging
pragma target CP0 DISABLED -- code block 0 not protected
pragma target CP1 DISABLED -- code block 1 not protected
pragma target CPB DISABLED -- bootblock code not write protected
pragma target WRT0 DISABLED -- table writeblock 0 not protected
pragma target WRT1 DISABLED -- table write block 1 not protected
pragma target WRTB DISABLED -- bootblock not write protected
pragma target WRTC DISABLED -- config not write protected
pragma target EBTR0 DISABLED -- table read block 0 not protected
pragma target EBTR1 DISABLED -- table read block 1 not protected
pragma target EBTRB DISABLED -- boot block not protected
pragma target HFOFST ENABLED -- THE_SYSTEM_CLOCK_IS_HELD_OFF_UNTIL_THE_HFINTOSC_IS_STABLE
include delay
include usb_serial
include print
-- constants
const byte str_welcome[] = "JALLIB USB Serial Demo app\n"
-- variables
-- interrupts? No thanks
INTCON_GIE = false
-- setup the USB serial library
usb_serial_init()
var bit has_shown_welcome_msg = true
var byte ch
-- main loop
forever loop
-- poll the usb ISR function on a regular base, in order to
-- serve the USB requests
usb_serial_flush()
-- check if USB device has been configured by the HOST
if ( usb_cdc_line_status() != 0x00 ) then
if !has_shown_welcome_msg then
print_string( usb_serial_data, str_welcome )
end if
else
has_shown_welcome_msg = false
end if
-- check for input character
if usb_serial_read( ch ) then
-- echo input character
usb_serial_data = ch
end if
end loop
Thanks for that Burt, have the Jalv2 compiler, and Jaledit already downloaded. Have slo-mo internet at the house, so maybe will download at the Java shop in the next couple of days.nickelflippr It's USB is great and if you can use Basic I think you said you use it You'll be right at home. The only bad thing is there not all on one site Here the whole thing I zip it up It's the latests just unzip go to the folder jaledit and run the ide jalEdit click on the help and you'll find all you need to get up and running with Jalv2
be80be:
Jal is nu to me...although I do have an 18f14k50 handy.
I was kinda hopin' to asm it, rather than learn another language. I have done GWbasic a long time ago though. Can u suggest an asm approach for the 18f14k50?
I see a guide in this link:
jallib: PIC 18f14k50 USB Interface Board: Part 4
But they suggest a 48Mhz clk speed. That may require a 4 layer board to manage crosstalk etc?
is a 48Mhz clk really required here?
