The output of the sensor is connected to the Timer Clock Input Pin of PIC16F877A. and LED connected to port pin RD0
I want to flash LED when the timer goes from 0 to 10 .
My code
I do not have any idea why LED doesn't flash when 10 counts happen?
I hope someone would help me here
My code
C:
/ PIC16F877A Configuration Bit Settings
// CONFIG
//MPLAB XC8
#pragma config FOSC = HS // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = ON // Watchdog Timer Enable bit (WDT enabled)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = ON // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF // Flash Program Memory Code Protection bit (Code protection off)
#define _XTAL_FREQ 20000000 //Specify the XTAL crystal FREQ
#include<xc.h>
void main(void)
TRISC = 0b00000001; //PORTC R0 pins are used as Input.
TRISD = 0b00010000; //PORTD R4 pins are used as output.
//Loading starting value of counter 65536- 10 = 65426 = FFF6 hexa decimal
TMR1H = 0xFF ; // High byte FF
TMR1L = 0xF6 ; // Low Byte F6
//Set T1CON Register
TMR1ON = 0; // Stops Timer1
TMR1CS = 0; // Internal clock (FOSC/4)
T1SYNC = 0; // Synchronize external clock input
T1OSCEN = 0; // Oscillator is shut-off
T1CKPS0 = 1; // 1:8 prescale value
T1CKPS1 = 1;
TMR1IE=1; //Enable timer interrupt bit in PIE1 register
GIE=1; //Enable Global Interrupt
PEIE=1; //Enable the Peripheral Interrupt
TMR1ON = 1; //Start Timer1
void interrupt timer_isr()
if(TMR1IF ==1)
RD4 = 1; // LED ON
__delay_ms(500); //
RD4 = 0; // LED OFF
TMR1IF=0; // Clear timer interrupt flag
