I am developing a wireless communication device using the CC2500 chip from TI. I need to communicate with the chip by SPI. I was simulating the circuit in Proteus using the SPI debugger but it Don't show any exchange of data. I have attached the Simulation Log and the SPI debugger connection here. Here is the code I use.
The content of ST24.h
Please help me. There is something wrong I am not able to figure out. There is actually no SPI communication is taking place.
I even tried using different "setup_spi" but still can't get it work. and why am i geting the messages
"ADC conversion clock period (1e-07) Possibly invalid for device clock frequency"
and
"Data written SSPBUF whilst MSSP(in Master mode) is active - data has been ignored"
Please reply. I will be waiting.
#include <16F876A.h>
#device adc=8
#FUSES NOWDT //No Watch Dog Timer
#FUSES HS //High speed Osc (> 4mhz)
#FUSES NOPUT //No Power Up Timer
#FUSES NOPROTECT //Code not protected from reading
#FUSES NODEBUG //No Debug mode for ICD
#FUSES NOBROWNOUT //No brownout reset
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD //No EE protection
#FUSES NOWRT //Program memory not write protected
#use delay(clock=20000000)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#include "ST24.h"
//#use spi(FORCE_HW, BITS=8,BAUD=9000000, stream=SPI_STREAM)
void main()
unsigned int8 Text[10];
unsigned int8 i=0;
int1 read=0;
unsigned int8 RSSI=0;
unsigned int8 LQI=0;
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
SETUP_SPI(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_4 | SPI_SS_DISABLED);
output_b(0xBF);
output_a(0x00);
delay_ms(600);
st24_init();
st24_initreg(0,5,0x10);
delay_ms(400);
output_b(0xFF);
while(1)
if(input(ST24_GDO2)==1)
if(read==0)
ST24_RX(Text,&LQI,&RSSI);
read=1;
else
read=0;
for(i=0;i<5;i++)
if(i==0)
output_a(0x3E);
output_b(0xFF ^ Text[i]); //Invert as we are using Comm Anode Type
delay_ms(5);
else if(i==1)
output_a(0x3D);
delay_ms(5);
else if(i==2)
output_a(0x3B);
output_b(0xFF ^Text[i]);
delay_ms(5);
else if(i==3)
output_a(0x37);
delay_ms(5);
else if(i==4)
output_a(0x1F);
delay_ms(5);
#define ST24_SI PIN_C5 //Serial IP of ST24 connected to serial OP of MCU
#define ST24_SCLK PIN_C3 //Serial Clock
#define ST24_SO PIN_C4 //Serial OP of ST24 connected to serial IP of MCU
#define ST24_CSN PIN_C0 //Chip Select Signal
#define ST24_GDO0 PIN_C1 //Digital output pin for general use
#define ST24_GDO2 PIN_C2 //Digital output pin for general use
int8 SRES=0x30;
int8 IOCFG2=0x00; //GD02
int8 PKTLEN=0x06; //Packet Length
int8 PKTCTRL1=0x07; //Packet Automation Control
int8 PKTCTRL0=0x08; //Packet Automation Control
int8 ADDR=0x08; //Device Address registor
int8 Address=0x00; //Address of the devices
void st24_init()
output_low(ST24_CSN);
while(input_state(ST24_SO)!=0x00)
//do nothing just wait
output_high(ST24_SCLK);
output_low(ST24_SI);
output_high(ST24_CSN);
delay_us(45);
spi_write(SRES); //Issue the SRES Command Strobe
//Now the chip isin idle state and al the registors have default values
//mode=1 for TX and mode=0 for RX Plen is the length of the packet UID is the unique Address for this device
void st24_initreg(int1 mode,int8 Plen,int8 UID)
Address=UID;
if(mode==0) //For RX
spi_write(IOCFG2);
spi_write(0x07); //GDO2 Asserts when a packet has been received with CRC OK. De-asserts when the first byte is read from the RX FIFO
else //For TX
spi_write(IOCFG2);
spi_write(0x06); //GDO2 Asserts when sync word has been sent, and de-asserts at the end of the packet.In TX the pin will de-assert if the TX FIFO underflows.
spi_write(PKTLEN);
spi_write(Plen);
spi_write(PKTCTRL1);
spi_write(0x0F);
spi_write(PKTCTRL0);
spi_write(0x44);
spi_write(ADDR);
spi_write(UID);
spi_write(0x4B); //burst mode access starting from FSCTRL1 registor i.e from address 0x0B
spi_write(0x06); //0x0B: FSCTRL1 – Frequency Synthesizer Control
spi_write(0x00); //0x0C: FSCTRL0 – Frequency Synthesizer Control NC
spi_write(0x5D); //0x0D: FREQ2 – Frequency Control Word, High Byte
spi_write(0x93); //0x0E: FREQ1 – Frequency Control Word, Middle Byte
spi_write(0xB1); //0x0F: FREQ0 – Frequency Control Word, Low Byte
spi_write(0x78); //0x10: MDMCFG4 – Modem Configuration
spi_write(0x93); //0x11: MDMCFG3 – Modem Configuration
spi_write(0x03); //0x12: MDMCFG2 – Modem Configuration
spi_write(0xA2); //0x13: MDMCFG1 – Modem Configuration
spi_write(0xF8); //0x14: MDMCFG0 – Modem Configuration NC
spi_write(0x44); //0x15: DEVIATN – Modem Deviation Setting
spi_write(0x07); //0x16: MCSM2 – Main Radio Control State Machine Configuration NC
spi_write(0x3E); //0x17: MCSM1 – Main Radio Control State Machine Configuration
spi_write(0x18); //0x18: MCSM0 – Main Radio Control State Machine Configuration
spi_write(0x16); //0x19: FOCCFG – Frequency Offset Compensation Configuration
spi_write(0x6C); //0x1A: BSCFG – Bit Synchronization Configuration NC
spi_write(0x43); //0x1B: AGCCTRL2 – AGC Control
delay_us(10);
/*spi_write(0x40); //0x1C: AGCCTRL1 – AGC Control NC
spi_write(0x91); //0x1D: AGCCTRL0 – AGC Control NC
spi_write(0x87); //0x1E: WOREVT1 – High Byte Event0 Timeout NC
spi_write(0x6B); //0x1F: WOREVT0 – Low Byte Event0 Timeout NC
spi_write(0xF8); //0x20: WORCTRL – Wake On Radio Control NC
spi_write(0x56); //0x21: FREND1 – Front End RX Configuration NC
spi_write(0x10); //0x22: FREND0 – Front End TX configuration NC
spi_write(0xA9); //0x23: FSCAL3 – Frequency Synthesizer Calibration NC
spi_write(0x0A); //0x24: FSCAL2 – Frequency Synthesizer Calibration NC*/
spi_write(0x65); //Start burst mode
spi_write(0x00); //0x25: FSCAL1 – Frequency Synthesizer Calibration
spi_write(0x11); //0x26: FSCAL0 – Frequency Synthesizer Calibration
/*spi_write(0x41); //0x27: RCCTRL1 – RC Oscillator Configuration NC
spi_write(0x00); //0x28: RCCTRL0 – RC Oscillator Configuration NC
spi_write(0x59); //0x29: FSTEST – Frequency Synthesizer Calibration Control Don't write
spi_write(0x7F); //0x2A: PTEST – Production Test No need to write
spi_write(0x3F); //0x2B: AGCTEST – AGC Test Don't write*/
delay_us(5);
spi_write(0x6C); //Start burst mode
spi_write(0x81); //0x2C: TEST2 – Various Test Settings
spi_write(0x35); //0x2D: TEST1 – Various Test Settings
/*spi_write(0x0B); //0x2E: TEST0 – Various Test Settings NC*/
delay_us(5);
spi_write(0x3E); //Access the PATABLE
spi_write(0xFF); //Write power setting to PATABLE
//M1 M2 Mode
//0 0 TX
//0 1 RX
//1 0 IDLE
//1 1 SRES(Reset)
void ST24_setmode(int1 m1,int1 m2)
if(m1==0 && m2==0)
spi_write(0x35); //Set the transceiver in TX mode
else if(m1==0 && m2==1)
spi_write(0x34); //Set the transceiver in RX mode
else if(m1==1 && m2==0)
spi_write(0x36); //Set the tranceiver in IDLE mode
else if(m1==1 && m2==1)
spi_write(0x30); //Reset the transceiver
int8 ST24_TX(Unsigned int8 data[],Unsigned int8 length)
int8 i=0;
int8 freeTX=00;
spi_write(0x7F); //Burst access to TX FIFO
spi_write(Address);
for(i=0;i<length;i++)
spi_write(data[i]); //write daTa to the TX FIFO
while(!spi_data_is_in())
//wait for data
freeTX=spi_read(); //READ daTa from the Transceiver
return freeTX;
int8 ST24_RX(Unsigned int8 *data[],Unsigned int8* LQI,Unsigned int8 *RSSI)
int8 RXBYTES=0;
int8 RXFIFO=0xBF;
int8 i=0;
spi_write(0xFB); //Read the number of bytes in the RX FIFO from RXBYTES
//wait for data
RXBYTES=spi_read();
RXBYTES=RXBYTES & 0x7F;
if(RXBYTES>0)
for(i=0;i<RXBYTES;i++)
RXFIFO++;
spi_write(RXFIFO);
//wait for data
if(i==RXBYTES-2)
*RSSI=spi_read();
else if(i==RXBYTES-1)
*LQI=spi_read();
*LQI=*LQI & 0x7F;
else
*(data+i)=spi_read();
return RXBYTES;
and
