Hello. I am having a small problem with an ultrasonic transmitter/receiver I built for a proximity sensor. I am using pwm from a pic at 24k (0.5 duty cycle) to oscillate a 24k ultrasonic transmitter. The receiver's signals go into a high pass opamp filter which also amplifies the signal 100x. The signal then gets rectified, and finally goes into an LED.
The circuit is kind of doing what I wanted. When I point the transmitter at the receiver, I expect to see the led turn on, which I do. However, as I move the transmitter towards or away from the receiver, I get points everyfew cm where the led goes dim. I think that the sound is somehow causing points of destructive interference, creating dead spaces. The same phenomenon happens when I point the transmitter/receiver pair at a wall.
Now my question is if this is typical of an ultrasonic transmitter/receiver? Is there a way around this problem, like if I transmit at slightly different frequencies?
Thanks.
Thanks.
