Ultrasonic range meter question.
DEADBAND / BLANKING The ultrasonic sensor sends out a sound pulse and then switches into a “listening” mode.
The time required for the sensor to recover from transmitting a sound pulse until it can detect a return echo
translates into a minimum distance from the end of the sensor required before a target can be detected.
The above quotation was taken from here and sums it up nicely. Hope that helps.
Ron
Some times this information is missing , then how can we find what is the switching/setteling time for a transducer . Like this spec **broken link removed** kHz&headline=150 kHz Thanks
The data sheet you linked to does not give effective range? If you spec a transducer that list min and max range it is easy to figure out. The spec you linked says nothing. I suggest you contact the manufacturer.
Ron
