Dragon Tamer
I have been working on what should be a fairly simple circuit for several weeks now and I haven't had any luck getting it to work. What I am trying to do is to find the current through a coil and detect if the current goes slightly higher than it's nominal current draw.
The circuit is for a stepper motor controller that I am designing and the circuit needs to be sensitive enough to detect a current ratio of a 1µA change for every 1mA of current draw (roughly). It is to work off of the principal of when the motor is running, and it gets stuck, the current through the coil increases slightly.
I have a circuit that I made that works to some extent, the problem is that it's not quite sensitive enough, but if I modify any of the values, it stops working properly. As of right now it has a ideal voltage detector, a coil current sensor, and a diff amp combining the two. I can post the schematic later, it's not finished yet.
Thanks for your help.
