Two's Complement Help.
To create the two's complement:
Write it out as a binary number ( 0 0 0 0 1 0 1 0 )
Invert all the bits
Add 1
You now have the twos complement, convert back to hex if required.
Invert all the bits
Add 1
A clear answer perfectly understood.
Thanks for your help.
my maths is not good we dont do much maths in school and dont do binary or hex but i am interested in learning this stuff so can you tell me if i got this write using your example please "(00001010)" so this inverted is 11110101?? is that right?? and adding 1 to it makes it 11110110??? and convert to hex (on the calculator) makes it f6??
do i have that correct?? one last question and i know its stupid but whats 2's compliment??
logan
Hey Logan,
You are correct. As you probably discovered, invert means to switch 0 to 1, or vice verse. Here are the series of steps:
Step 1: Record First Value:
Step 2: Invert:
Step 3: Add 1:
In binary, you increment in doubles reversely, thus:
128, 64, 32, 16, 8, 4, 2, 1
So if you examine the red portion in step 2:
1 1 1 1 0 1 [COLOR="Red"]1 0[/COLOR]
You will notice that the '1' is in the 1's value, so adding another 1 would put it in the 2's place.
It's what I just showed you. Although I think you are referring to why it is used? The answer is fun of course! ;)
I only know it, but I haven't used it for anything. I'm sure others would be able to tell you applications.
2's compliment is a good way for expressing numbers that are negative or positive.
It is often used on Centigrade temperature sensors that cover ranges like -55º to +125º C.
One way of looking at 2's compliment is that the most significant digit represents minus what it would represent in binary. An 8 bit temperature would have bits that represent
-128º C
64º C
32º C
16º C
8º C
4º C
2º C
1º C
"(00001010)" so this inverted is 11110101?? is that right?? Yes, this is also known as the 1's complement
do i have that correct?? Yes. correct again
As others have said, the 2's complement is a way of writing negative numbers in binary.
So, the original hex number 0x0A which is equivalent to 10 in decimal has been converted to the hex equivalent of -10 in decimal.
And just as 10 + (-10) = 0 in decimal, so a binary number added to its 2's complement is also zero.
As a side issue, at the machine level, computers work in binary.
For us humans trying to remember binary numbers is a real pain (at least it is for me!), so hexadecimal is just a convenient way of remembering and writing binary numbers.
