Sorry, but again you're completely wrong - there's no specific need to use interrupts for a software UART - and most don't do it, I've certainly never found any requirement to.Google it, you should easily find software UARTs code in C for PIC's, mind you they're typically sensative to the clock speed of the PIC you're running, a lot moreso than hardware because it's done all in software using interupts.
No problems whatsoever, PIC's are far faster than that - however, if you read the original post, you will see he only wants to TRANSMIT data, which you could easily and simply do using multiple software UART's for as many channels as you wanted.Depending on how much data you're transmitting between the two devices you may run out of processing speed fast enough to handle both the hardware and software uarts at the same time though and you'll start getting corrupted data.
What C compiler do you use? Microchip have examples for C18 in their reference guide that explain how to use both hardware and software USART.Does somebody have "Software USART" code in C?
No, because that's why you keep ISR's short and fast, so it's not long enough to cause problems for any normal sort of baud rates - you're probably going to get problems trying to run a software UART at 115Kb, but at the more normal 9600 baud it's not a problem at all. Also, choosing which you use for TX and which for RX makes a difference, depending exactly what you're doing - even at 115Kb.Nigel I'm not wrong just backwards close enough to wrong though, I was thinking of receiving. For reception at some point an interrupt is going to cause an ISR during the software UART's delay routine and desync it.
