turn the dc motor using 16F877A
too fast
Hi there..now im doing a project using one wire DS18S20 and display the temperature on 4 digit 7-segment. I would like to add 5v dc motor as cooling fan. the fan will start running when temperature reach 60 C and above.
Anybody can help me in programming in order to run the dc motor (constant speed)..below is my source code to display temperature. Since port C and D have been used, i would like to use port A.
Define LOADER_USED 1
DEFINE OSC 4
@ Device pic16F877A, xt_OSC, BOD_OFF, PWRT_ON, WDT_OFF, PROTECT_OFF 'WRT_On
Segments Var PORTC
Digits Var PORTD
i Var Byte
n Var Byte
Value Var Word
' Allocate variables
command var byte ' Storage for command
J var byte ' Storage for loop counter
temp var word ' Storage for temperature
T VAR WORD
DQ var PORTd.4 ' Alias DS1820 data pin
DQ_DIR var TRISd.4 ' Alias DS1820 data direction pin
read_done var byte
Lastdata var word
TRISc = $00 ' Set segment pins to output
TRISd = $f0 ' Set digit pins to output
TrisB = $00
Portb = $00
portd = $ff
OPTION_REG = $50 ' Set TMR0 configuration 1:64
INTCON = $A0 ' Enable TMR0 interrupts
'On Interrupt Goto display
'ADCON1 = 7 ' Set PORTA and PORTE to digital
' Lcdout $fe, 1, "Temp in degrees C" ' Display sign-on message
'debug ====
DEFINE HSER_RCSTA 90h
DEFINE HSER_TXSTA 24h
DEFINE HSER_SPBRG 12 ' 19200 Bauds ,4 m
'debug ====
' Mainloop to read the temperature and display on LCD
mainloop:
'goto display
'Goto mainloop
Gosub init1820 ' Init the DS1820
command = $cc ' Issue Skip ROM command
Gosub write1820
command = $44 ' Start temperature conversion
Gosub write1820
'Pause 2000 ' Wait 2 seconds for conversion to complete
Gosub init1820 ' Do another init
Gosub write1820
command = $be ' Read the temperature
Gosub write1820
Gosub read1820
'Display the decimal temperature
'HSEROUT ["Temp = ",dec (temp>>1),".", dec (temp.0*5)," C",13,10]
'T = ((temp>> 1)*100)+((TEMP.0*5)*10)
'HSEROUT ["Temp = ",dec T ,13,10]
value = ((temp>> 1)*100)+((TEMP.0*5)*10)
GOTO DISPLAY
Goto mainloop ' Do it forever
' Initialize DS1820 and check for presence
init1820:
Low DQ ' Set the data pin low to init
Pauseus 500 ' Wait > 480us
DQ_DIR = 1 ' Release data pin (set to input for high)
Pauseus 100 ' Wait > 60us
If DQ = 1 Then
'Lcdout $fe, 1, "DS1820 not present"
PORTC = $39
LOW DIGITS.0
PAUSE 150
PORTC = $0
Pause 150
Goto mainloop ' Try again
Endif
Pauseus 400 ' Wait for end of presence pulse
Return
' Write "command" byte to the DS1820
write1820:
For i = 1 to 8 ' 8 bits to a byte
If command.0 = 0 Then
Gosub write0 ' Write a 0 bit
Else
Gosub write1 ' Write a 1 bit
Endif
command = command >> 1 ' Shift to next bit
Next i
Return
' Write a 0 bit to the DS1820
write0:
Low DQ
Pauseus 60 ' Low for > 60us for 0
Return
' Write a 1 bit to the DS1820
write1:
Low DQ ' Low for < 15us for 1
@ nop ' Delay 1us at 4MHz
Pauseus 60 ' Use up rest of time slot
Return
' Read temperature from the DS1820
read1820:
For i = 1 to 16 ' 16 bits to a word
temp = temp >> 1 ' Shift down bits
Gosub readbit ' Get the bit to the top of temp
Next i
Return
' Read a bit from the DS1820
readbit:
temp.15 = 1 ' Preset read bit to 1
Low DQ ' Start the time slot
If DQ = 0 Then
temp.15 = 0 ' Set bit to 0
Endif
Pauseus 60 ' Wait out rest of time slot
Return
'================== 7 seg ment display ==============================
display:
'value = ((temp>> 1)*100)+((TEMP.0*5)*10)
PORTC = $39 'Show C on display
LOW DIGITS.0
PAUSEUS 1500
PORTC = $0
'value = 125
For i = 1 To 4 ' Loop through 4 digits
n = Value Dig i ' Get digit to display
' Gosub display1 ' Display the value
Digits = $ff
Lookup n, [$3F, $06, $5B, $4F, $66, $6D, $7D, $07, $7F, $6F,_
$77, $7C, $39, $5E, $79, $71, $0FF], Segments
If i = 2 then segments = segments + 128 'Digit 2 show dot
Digits = ~Dcd i
NEXT I
goto mainloop
please any one...
I have used 'Pommies' code tidy.
Its helpful when you post code to Select it and click the '#' Code symbol on the menu bar, this keeps the formatting and makes it easy to read.:)
DEFINE	OSC	4
Segments Var	PORTC
Digits	Var	PORTD
i	Var	Byte
n	Var	Byte
Value	Var	Word
T	VAR	WORD
read_done var	byte
Lastdata var	word
TrisB	=	$00
Portb	=	$00
portd	=	$ff
'debug	====
'debug	====
mainloop:
'goto	display
'Goto	mainloop
Gosub	write1820
Gosub	write1820
Gosub	write1820
Gosub	write1820
Gosub	read1820
	goto	DISPLAY
	goto	mainloop ' Do it forever
init1820:
	if	DQ = 1 Then
PORTC	=	$39
LOW	DIGITS.0
PAUSE	150
PORTC	=	$0
Pause	150
	goto	mainloop ' Try again
	endif
	return
write1820:
	if	command.0 = 0 Then
	else
	endif
Next	i
	return
write0:
Low	DQ
	return
write1:
	return
read1820:
Next	i
	return
readbit:
	if	DQ = 0 Then
	endif
	return
display:
LOW	DIGITS.0
PAUSEUS	1500
PORTC	=	$0
'value	=	125
Digits	=	$ff
	if	i = 2 then segments = segments + 128 'Digit 2 show dot
Digits	=	~Dcd i
NEXT	I
	goto	mainloop
can i borrow your code too fast?!,.. please,.. coz i have the same project,... thank you,...
