Billy Mayo
The Op-amps that have the fixed trip points are either Tripped by
1.) The voltage level
2.) The Current Level
Are these Op-amp comparators? or are they something else
Because I can't tell when a Comparator is being tripped by a voltage level or a current level to trip the input so the op amps output switches states
How can you tell?
At work some Op-amps at tripped by a Fixed DC voltage of +10 volts , but it only tripped the input of the op-amp if you adjust the current to .300mA
The Op-amp won't trip if you adjust the voltage, it only trips when you apply a current level of .300mA
How can you tell when an Op-amp circuit or a comparator is tripped by current and not voltage?
Another thing I do at work is , I have to TIME how long the Op-amp or Comparator switches states from input to output, to measure how long it takes to trip the input and for the output to change switching states, What is this called what I am doing?
How can you tell?
