Triggering a camera with light
Arnaud
Folks,
I am looking for an easy electronic circuit that close a switch. Here is what I want to do...
I would like to take pictures of lighting storm. My idea is to trig the opening of my camera when light from the storm is detected. So, I need do build a circuit that does the following :
- 1 - detect visible light
- 2 - close a switch (= the switch of my ML-L3 Nikon wireless remote control, not the switch of my camera...)
Well, this project is surely not difficult for most of you but I am not very good in electronics... I guess it takes a diode to detect the light, a transistor to amplify the output current of the diode and a electro-mechanical switch.
Thanks for your help,
Arnaud (from France!)
By the time the light has been detected and the switch actuated the lightning flash will have ended :(
Of course, by the time the light has been detected and the switch actuated the lightning flash will have ended but... I hope a second flash will come right after. The camera can be setted to stay open for some second to capture even several following flashes.
I found several "circuits controlling switches" on the web but none of them can be trigged by milisecond curent pulses coming from a photodiode.
Arnaud
About 40 years ago in an electronics magazine here was an article about this. They used a old AM radio to detect lighting. The radio, tuned to no station, produces a strong output and triggers a 555 that holds the camera open for 2 seconds.
No!
As soon as the sensor is hit by a lightning it should trigger the camera shutter with no delay.
I have used cheap slave flashes to be activated on a master flash. The photos showed that the speed was OK and the pictures were just great.
Lightnings don't burn for a split of a second, but normally between one and several seconds.
You'll have to decide if you use either an LDR, a photo diode or a photo transistor for sensor.
Check out the datasheets to find out the most effective speed for your project.
Good luck
Boncuk
