Triac light bulb flasher [Deleted]
ElectroMaster
Administrator
ElectroMaster submitted a new article:
Triac light bulb flasher - This 800 W light bulb flasher operates directly off the line and needs no transformer. Power for th
This 800 W light bulb flasher operates directly off the line and needs no transformer. Power for the timer circuit is derived by limiting the current using a 330 nF capacitor (acts like a 9.6 k resistor at 50 Hz), rectifying with a full-wave rectifier composed of four diodes (you may also use a pre-made bridge rectifier instead of the diodes, of course, but make sure the voltage rating is 400 V, or 250 V RMS). Then the voltage is limited with a 9 V zener diode (almost any of this voltage will...
Read more about this article...
