I had my treadmill trip the ground fault indicator last night during use, and continues to do so when flicking on the treadmill's power switch.
The treadmill's 15A circuit breaker is not being tripped.
The treadmill does not trip the GFI when the motor is disconnected from the motor controller board (PWM).
The motor is a DC brushed permanent magnet (2 wire), but with no markings beyond 4000RPM/10A I can not track down datasheets to see what its winding resistance should be. It measures (via multimeter) 2Ω.
The motor spins without problem by hand, but becomes harder to spin when the terminals are shorted.
So I feel the motor itself is ok. It was not hot to touch upon failing.
With the motor disconnected, neither of its terminals are shorted to the earthed chassis.
Although the controller board attaches to the chassis via its heatsink, ithe board appears to be electrically isolated from its heatsink.
So I'm at a bit of loss here. If the ground fault indicator is immediately being tripped, before the motor is even being told to spin, something is shorting to earth. I just can't imagine what?
