I have recently become interested in Falconry however a common problem with this hobby, especially at the start, is loosing the bird...
you can get around this by fixing a transmiter (at 173.243Mhz) to the birds tail and wonderering around with a reciever hoping you can find it. I dont really want to loose a £350 pound bird so this seams like a sensible option right?
I'm a bit of a budding electronics enthusiast but I am new to it all. So when I found out that these transmiters were prohibitivly expensive I figured I could just build one myself? I asked around and someone supplied me with a broken (it has been run over) transmiter.
Now in front of me I have a Hartly ? transmiter circuit that uses coil (about 5:1) ratio, resistors, capacitors a transistor and what looks like a hc-49 quartz resonator (smashed) to produce the required frequency. As the crystal is smashed I dont know of any way to work out what I should buy to replace it. I assume with the values of that other components I could work out what crystal I need. I hoped that maybe the people here could give me a few hints on where to start looking and what I should be looking for to get me started.
The values of the components I have here are:
1 x 820r @5% tol resistor
1 x 850r @1% tol resistor
1 x 3E transistor (PNP transistor?) my search brought up BC857A as a p/n
1 x 102 capacitor (ceramic)
1 x 15k (?) ceramic capacitor
1 x coil setup at aprox 5:1 ratio
1 x broken HC-49 crystal (might be different)
1 x 3.7v silver cell 720mAh
Anything you could tell me would be much appreciated as it is a very interesting subject for me and I have not long discovered it!
another option is to create the circuit from scratch though to do that I need to think about battery life and weight.
Cheers in advance
Luke Alden
Cheers in advance
Luke Alden
