transistor replacement
mike03
I have a few transistors that I know is from european manufactures and hence can be hard to find at some local stores. BC556B,BC557B and BC547B can someone give me the replacements for these?thank you they are from amp circuit.
2N2907 and 2N2222 which are PNP and NPN respectively.
The pinouts will be opposite, check the datasheet if you're unsure.
They're both NPN which is fine to replace the BC547 with but you need PNP to replace the BC556/7 with.
